X300 oil cooling lines
Old Aug 29, 2022 | 11:35 PM
BobbyDing's Avatar
Default X300 oil cooling lines
So today one of the cooling lines burst. Not sure which one yet (NBA4510BB or NBA4500BB). Figured we'd replace them both while we're at it. So far I've mostly found them only on ebay. Any suggestions of other possible suppliers? And how difficult are they to replace?
Thanks very much for any assistance!!
Bobby
Old Aug 29, 2022 | 11:48 PM
watto700's Avatar
G'day Bobby,
I have a V12 car and one of my oil cooler hoses burst several years ago and the replacement hoses were unbelievably expensive and also unavailable so I took both of my hoses to a local hydraulics workshop and had them re-hose them for about a tenth of the OEM replaement cost.
It has been over ten years now and no trouble.
Cheers,
Jeff.
Old Aug 30, 2022 | 09:04 AM
katar83's Avatar
You dont need oil cooler on your non SC X300. Remove both and the cooler and fit a Jaguar bypass, or if you cant be bothered or dont have time getting one, just remove the oil lines block and bolt the oil filter housing directly to engine with some shorter bolts.
Jaguar part number: EBC4124
Old Aug 30, 2022 | 10:40 AM
BobbyDing's Avatar
Thanks for this info. @watto700, I considered taking the old lines to a transmission shop to see if they can be rebuilt. That'll be option 1. For option 2, @katar83, so your saying the cooling is not required for a non super charged car, and I can just bypass/plug those lines? The cooler is part of the radiator and not a separate unit. These are for the automatic transmission (don't think I specified that in the OP). Would we still be safe to bypass this? Also, what type of transmission fluid should we be using? My local parts store could not find the type of fluid required for a 1996 x300?
Thanks!
Bobby
Old Sep 2, 2022 | 10:12 AM
BobbyDing's Avatar
Any suggestions about type of fluid we should be using in the x300? Our local parts stores can't locate a definite type of fluid for a 1996 xj6.
Old Sep 2, 2022 | 10:58 AM
Parker 7's Avatar
This is for the automatic transmission for a non - supercharged engine / transmission ( ZF4HP24 )
08-1-05 (jagrepair.com)
Genuine Dipstick And Oil Cooler Pipes-3.2/4.0 Litre-naturally Aspirated (3.2 Litre,4.0 Litre,4.0 Litre (california),automatic) For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
Old Sep 3, 2022 | 10:49 AM
BobbyDing's Avatar
Thank You!
Old Sep 26, 2022 | 06:04 PM
BobbyDing's Avatar
Just a follow up. The issue was the transmission cooling lines. I forgot that many models have cooling lines for the engine as well. My apologies. As for the broken cooling lines, the break was in one of the rubber sections of the two lines. We were able to replace the rubber hoses on both lines with "6AN" 3/8" industrial rated line and better quality hose clamps from Amazon. A single 10" section was enough. I moved the original part number tags over as well for no particular reason. Photo included here.
Thanks to all that helped!
Bobby
mirisisa
Dec 18, 2019 09:13 AM
centaur15
20
Dec 12, 2019 09:20 AM
muttony
Jul 29, 2019 11:14 AM
jagxkrtoofast
Jun 11, 2011 07:51 AM
