Look at Papa Indy 104 pin 18 on the ECU as this is the ECU provided ground command to close the large # 5 right ECU controlled relay that both brings power ( used at all times ) into the ECU . powers the fuel injectors to open and 1/ 2 of your engine sensors
This large relay must click in your finger tips with key in run and or relay removal as a single person operation with key in run
