X300: Rear light fuse
Old Jan 26, 2024 | 09:56 AM
fab88's Avatar
Default X300: Rear light fuse
Good morning,
My rear right lights & my front right bulb
(in pilot mode) no longer work
in code mode it works on the front.....
So I search, the Fuse Location
Thanks for your help!
Soon on our roads ......
Bonjour,
Mon feux arriere droit & mon ampoule droite avant
(en mode veilleuse) ne fonctionnent plus
en mode code cela fonctionne à l'avant.....
Je recherche donc, l'Emplacement du fusible
Merci de votre aide !
et a Bientôt sur nos routes ......
Old Jan 26, 2024 | 10:45 AM
Parker 7's Avatar
There was some upsizing of the fuses in this TSB
15-16 (jagrepair.com)
Notice the difference to the VIN 720001-739426 as this early ( 95 ) external lamp module is 2 separate modules under the front bonnet
The later version only has 1 external lamp module in the boot
Old Jan 26, 2024 | 10:49 AM
fab88's Avatar
OK
but where exactly is the fuse???
I don't really understand
Old Jan 26, 2024 | 10:50 AM
fab88's Avatar
Jaguar x300 3.2l sovering de 1996
Old Jan 26, 2024 | 10:52 AM
Parker 7's Avatar
Stand by
Old Jan 26, 2024 | 10:55 AM
Parker 7's Avatar
See page starting on page 21
X300 1996 LWB.pdf (jagrepair.com)
There are some other issues other than the fuses , the external lights can be a pain to work , so takes patients
Old Jan 30, 2024 | 06:32 PM
fab88's Avatar
ok thank you this works again
fuse 5A left side motor #5
See you soon on our roads!
Old Feb 3, 2024 | 05:58 AM
fab88's Avatar
Good morning,
I come back quickly on this topic
indeed, it starts again after the fuse change
It "flashes" even, defois its walk after its walk more!
So what do you think?
(can be fuse 7A or 10A??)
Old Feb 3, 2024 | 07:33 AM
Parker 7's Avatar
the indication light flashing can mean the wrong size bulb ( out of range of what the current sensors want to see )
This can be caused by both the bulb and bad connections
Old Feb 3, 2024 | 10:07 AM
fab88's Avatar
the bulbs have not been changed
only the fuse
Old Feb 4, 2024 | 10:55 AM
Parker 7's Avatar
Are those the turn signals ( direction ) or the park lights ?
Do the turn signals behind the front wheels work ?
Old Feb 5, 2024 | 11:11 AM
fab88's Avatar
It is the main beam
the turn signals are ok
On the other hand, it starts again
The fuse of 5A slams
There I was forced to disconnect battery to reorder
I don’t know what to do or where to go??
Old Feb 5, 2024 | 11:38 AM
Parker 7's Avatar
Never install the battery backwards , positive post fwd
Never over tighten the battery positive post bolt , breaks the curved nut underneath
Headlights OK ?
Engine running OK ?
I didn't understand your last post
Old Feb 5, 2024 | 12:56 PM
fab88's Avatar
the fuse 5A reclaque
it’s happening again
Old Feb 5, 2024 | 02:00 PM
Parker 7's Avatar
The fuse 5 amp , which fuse box and what position number ?
The # 1 fuse is closest to the terminal post on the fuse box
Old Feb 6, 2024 | 02:02 AM
fab88's Avatar
Gearbox engine compartment left side
Fuse Location N°: 5
5 Amps
Old Feb 6, 2024 | 06:54 AM
Parker 7's Avatar
See page 21
This Doc shows 10 amp
And this Doc shows 5 or 10 depending on the last 6 numbers of the VIN
The early X300s has 2 external light control modules up front under the hood , the later has 1 under the rear trunk like mine VIN 755xxx
So there was some changes in fuses
Cgo
Dec 31, 2024 02:53 PM
Ray Ray
Apr 10, 2020 06:28 PM
Galaxie390
XJ40 ( XJ81 )
May 8, 2019 09:28 PM
josephgreene
Mar 1, 2018 04:24 PM
kicknhard
Jun 14, 2014 10:32 PM
