X300 security module location
Old May 21, 2013 | 03:07 AM
mgsheridan's Avatar
Default X300 security module location
The alarm is not sounding and most probably not working. the key fobs open and lock the car but no 'bleeps' are heard. I have replaced the sounder and now assuming it is the security ecu. Can anyone tell me where I can find the security ecu on my 1997 x300 sport Thanks Mike
Old May 21, 2013 | 03:51 AM
No idea where you are so I will guess it is in the same place RHD, or LHD??.
Mine (RHD) is tucked up between the fuel filler spout and the outer metal body panel inside the boot. Trim panel removal will be required, and a sense of humour will help heaps.
Old May 21, 2013 | 04:35 AM
x300man's Avatar
i believe it is under fuse box in boot where battery is
Old May 25, 2013 | 10:33 PM
avioni's Avatar
it is located right under the fuel filler. u will need to remove two bolts to get it free. the security sounder uses 2 wires from the security module. these are on the longest plug identified as the CA21 plug. pins number 13 and 26 are for the sounder. those are the first two wires on the left of the CA21. colors are white/orange and white/slate, they both carry little less than 6 volts when the alarm should be sounding.
Old May 27, 2013 | 01:52 PM
mgsheridan's Avatar
Hi Guys
Thanks for the information unfortunately I cannot find it under the fuel filler pipe or under the battery
Anyone else got any ideas
Regards
Mike
X300 RHD 1st registered 1/10/1997 . bought by me October 1998
Old May 27, 2013 | 03:30 PM
x300man's Avatar
take the fuse box out that is behind the battery it is under there
Old May 28, 2013 | 06:48 AM
Urchins's Avatar
Thake a look here, may be it will help - JagRepair Documents and Tips
DevonDavid
Jan 8, 2026 03:12 PM
aholbro1
Dec 29, 2024 06:46 PM
Forcedair1
Feb 19, 2020 01:51 PM
Iain Yates
Sep 16, 2015 06:48 PM
Tipptone
Sep 16, 2015 07:39 AM
