X300 Steering problems
Old Sep 2, 2019 | 06:35 AM
Chris777's Avatar
Default X300 Steering problems
Hello everyone!
Primary:
An often addressed problem (but always without result, since the discussants always came off the topic):
Steering after cold start normal - after a few kilometers stiff! Does that know someone and its remedy?
Pump replaced overhauled, steering gear around 2000 kilometers old (new part)! OK ... maybe the bad luck with again faulty pump would be possible. However, I read in various forums that the problem continued to occur even with new pumps.
Are there any other components that could influence the steering effort?
Secondly:
Speedometer remains dark when the light is on. Likewise, climate keys and window switch in door.
Replaced / tested dimmer switch and module for interior lighting LXF 6490AA, fuses, etc.
No success: Turn the light switch and the above things stay dark.
Odometer, clock, climate display, however, shine!
Thank you in advance for tips and maybe you have ever had the experience and found a solution?
Greetings Christof (Austria) ...sorry for my bad English
Old Sep 2, 2019 | 08:48 AM
Lady Penelope's Avatar
On some models of the X300 it has speed variable steering and may be stuck in the high speed restricted mode
https://www.jaguarforums.com/forum/x...-issue-191501/
Old Sep 2, 2019 | 08:56 AM
Chris777's Avatar
Hello Lady Penelope!
Thank you for the quick and helpful answer!
Best regards from Austria, Christof
Old Sep 3, 2019 | 12:36 AM
watto700's Avatar
G'day Christof,
As well as all the good information from Lady P check the electrical plug on the steering rack itself, they can sometimes become loose if not seated properly after having work done on the steering rack
Cheers,
Jeff.
Old Sep 3, 2019 | 01:46 AM
Chris777's Avatar
Good morning Jeff!
Thank you too for the tip!
We will check this Things on Saturday...
I will tell, if we found something!
Best regards, Christof
Old Sep 12, 2019 | 07:24 AM
Chris777's Avatar
Hello everyone!
Good news ... It was the relay left behind the cover (in the foot area / behind bonnet opener)
It was just too loose put in!
Thank you all!
THANK YOU THANK YOU THANK YOU
Great forum and a great help !!!
Christof from Austria
Old Sep 12, 2019 | 07:27 AM
Chris777's Avatar
Greetings from Austria
Chris777
Sep 2, 2019 06:31 AM
Jacob67
Apr 20, 2019 06:17 PM
ALu
Nov 6, 2017 01:39 AM
Serlock
Mar 10, 2017 10:14 AM
