X300 type of power steering fluid
Old Nov 22, 2015 | 10:14 PM
EZDriver's Avatar
Smile X300 type of power steering fluid
I am in the process of changing the power steering fluid. It has been recommended the I use synthetic fluid. The only synthetic I can find is Valvoline ATF Dexron-VI Full Synthetic. Does any one see a problem with using automatic fluid in the power steering system? I have not used synthetic in the system before. Any one see a problem with mixing the types until I am able to get a complete change?
Thanks guys.
Old Nov 22, 2015 | 10:28 PM
No problems at all.
After about 5 syringe out and refills over, say a week, the concentration will be sweet.
I use Synthetic ATF in all mine, always have.
Old Nov 23, 2015 | 09:55 AM
EZDriver's Avatar
Thanks Grant. I'll do that on a regular basis in the future.
Old Nov 23, 2015 | 06:27 PM
motorcarman's Avatar
The ZF power steering system in the car uses DEXRON ATF from the factory.
Some of the the XJ40 used HSMO and the 2000 S-Type (ESSO 998 for the Ford rack) were the only recent Jaguars to use something else in the PAS system.
I'd use what Grant used.
bob gauff
Old Nov 24, 2015 | 04:11 AM
Thanks Bob.
I had to hunt down that S Type fluid for the Black Beast, and down here it was a PAIN, but all good now. I suspect it had ATF in it, as it was juddery when first owned by me, now sweet as, and it took 8 suck and refills without going too low and getting air in the damn thing, HA.
Now I typed that I might just give it another suck and refill tomorrow morning, coz I can.
Old Nov 24, 2015 | 08:05 AM
EZDriver's Avatar
Thanks guys for all your trouble. Always a big help. Now the messy part.
Old Nov 25, 2015 | 10:51 AM
al_roethlisberger's Avatar
My minor then later tremendous return line leak last year helped me fully flush mine out over a few months
I used Valvoline Dexron 6 synthetic ATF because that's what I had. Worked fine.
Although it is possible, I doubt the steering pump and rack has the same potential sensitivity to the difference between Dexron 4 and 6 as a transmission might.
Dean9785
Mar 21, 2016 08:21 AM
VancouverXJ6
XJ40 ( XJ81 )
Nov 10, 2015 10:12 PM
alclarkey
Oct 29, 2015 08:57 PM
1 of 19
25
Oct 29, 2015 11:02 AM
Ymss845
Oct 26, 2015 01:16 PM
