X300 won't start
Old Apr 4, 2015 | 07:46 PM
ltdupdate's Avatar
help
Old Apr 4, 2015 | 07:51 PM
Don B's Avatar
Originally Posted by ltdupdate
help
Hello ltdupdate,
Welcome to the Jaguar Forums.
How can we help you?
We're a friendly group, but we do ask that you visit the New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post an introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Old Apr 4, 2015 | 07:52 PM
ltdupdate's Avatar
hi guys this is a great Jag Forum...only just joined.. you guys are very cluey...
I just bough my son a 1997 x300 3.2ltr heritage LWB...
but it wont start... ive gone though just about all links and posts ...but it just wont fire up, though it tries...I have replaced the plugs, all coils.. engine crank sensor.. checked all fuses and relays... checked full pump with a gauge, and pressure regulator are good to...also.. in the dark of last night, we tried again, now I find the small wire going to the starter motor Solenoid is sparking up.. please help, as I seriously need it.. cheers Rick .. Sydney Australia..
Old Apr 4, 2015 | 08:22 PM
Don B's Avatar
Hi Rick,
If the engine turns while cranking, then I doubt the sparking at the starter solenoid wire is the ultimate problem, but you do want to sort out why it is sparking.
Probably the number one cause of a Jaguar engine cranking but not starting is low battery voltage. If the voltage sags much below 11V while cranking, the Engine Control Module (ECM) will not trigger the ignition to fire the coils/plugs.
If you have a fast-reacting voltmeter, you can have your son crank the engine while you monitor the voltage across the battery terminals.
You can also check for spark with an inexpensive coil-on-plug tester or by pulling a plug, connecting it to the coil, and grounding its threads.
P.S. I deleted your duplicate post in the other thread so all the responses you receive will be in the same thread and other members won't waste time by replying with the same information someone else has already provided in the other thread.
Cheers,
Don
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
