Xj6 1997 vdp trunk buttons not working
Old Jul 16, 2024 | 12:14 PM
TRUND's Avatar
Default Xj6 1997 vdp trunk buttons not working
Hello Guys,
Well, the pushbutton cat on the trunk lid AND the dash button, BOTH don't work to open my trunk.
I am not sure if they both went out at the same time, because i am not the original owner. The key insert in the trunk lid works, luckily.
What would be my first 3 troubleshooting steps?
Thank you all in advance for your help,
Ted
Old Jul 16, 2024 | 06:33 PM
944play's Avatar
Inspect the wiring at the flexure point on the right trunk hinge.
Old Jul 16, 2024 | 06:59 PM
TRUND's Avatar
944play,
I'll take your advice and it will be my weekend project if things cool down around here (NYC).
THANKS,
TED
Old Jul 25, 2024 | 09:30 AM
Alexander Gurney's Avatar
I had a problem with my boot(trunk) lid push button as it became inoperative. I acquired a replacement that did work. However, on attempting to remove the push-button assembly, one has to remove the chrome plated lid moulding. Mine is plastic and the securing washer/spring clip will not release it and that resulted in a broken retaining peg! Needless to say I left it at that!
Old Jul 25, 2024 | 12:51 PM
motorcarman's Avatar
If the car is in VALET MODE it is completely normal.
If the system is NOT in valet mode, check the boot lid wiring at the hinge point.
The valet mode can only be cancelled by opening the lid and the car recognizing that it is open.(boot lid switch functional)
Old Jul 25, 2024 | 01:33 PM
TRUND's Avatar
motorcarman,
Is there a button on the dash that puts my 1997 xj6 vdp into, and out of VALET MODE ?
TED
Old Jul 25, 2024 | 02:08 PM
The switch should be in the center console cubby.
Old Jul 25, 2024 | 04:26 PM
TRUND's Avatar
Thanks motorcarman.
Ted
Old Jul 26, 2024 | 05:15 PM
Cafcpete's Avatar
The switch will only put you IN to valet mode, as motorcarman said, only opening the boot will take you OUT.
Old Jul 26, 2024 | 05:38 PM
TRUND's Avatar
Cafcpete, thanks for info. Can you send a clear photo of the cubby button ? Ted
Old Jul 26, 2024 | 05:53 PM
944play's Avatar
Old Jul 27, 2024 | 09:44 AM
When I worked at the dealer, I would get requests from the customer for info about things like..HOW DO I PROGRAM MY GARAGE DOOR OPENER?
The service writer would ask for me a print-out procedure in my literature from training classes.
It was easier to find the OWNER'S MANUAL and walk to the copy machine, place the 8.5" x 11" paper folded into the owner's manual between the copied pages and lay it on the front seat.
I got called into the office one day and the service writer said that the customer was NOT AMUSED with the copied paper.
I explained that all the info was in the owner's manual. He agreed but just wanted to tell me about the customer's reaction.
RTFM is an acronym worth repeating.(I have been known to be a 'smart-***')
SMART-***: DEFINITION
Someone that can sit on an ice cream cone and tell you what flavor it is.
Old Jul 28, 2024 | 10:13 AM
TRUND's Avatar
944 Play,
Thanks for the two graphics. "They" told the story.
Ted
Gpktwo
Oct 2, 2023 02:09 PM
kehollins
Jul 11, 2023 11:15 AM
RalphFurley
Aug 31, 2016 01:57 PM
kksgirl
Oct 4, 2011 06:57 AM
bobalew003
Jul 28, 2011 11:34 PM
