XJR O2 sensors-Bad and Expensive
Old May 5, 2011 | 11:11 AM
XJR96's Avatar
Unhappy XJR O2 sensors-Bad and Expensive
So my O2 sensors are bad and called Jaguar dealer for parts qoute. It came out to $3000. That half the car's value. So my question is can I use the cheap universal sensors to replace the current? Or any other Ideas.
Old May 5, 2011 | 02:27 PM
imagineaudio's Avatar
Not sure how many 02 sensors the xjr has, 2 upstream and 2 downstream?
Very unlikely that all of them are bad.
Rock Auto has an exact fit replacement, according to their site, at $152.00: 1997 JAGUAR XJR Oxygen Sensor
Old May 5, 2011 | 02:37 PM
Doug's Avatar
No, you can't use "universal" sensors. You need titania sensors but, as mentioned, do some shopping around for lower priced choices. I think you might find 'em for as little as $80-$100 each.
I also I agree that all four being faulty is stretching things a bit....although it's technically possible. What are the symtpoms, trouble codes, etc?
There are other possible faults that can might make an oxygen sensor seem bad when it isn't.
If you replace 'em make darn sure you don't get the connectors mixed up.
Old May 10, 2011 | 09:57 AM
xjrguy's Avatar
The titanium dioxide [titania] sensors are rather robust in operation, except when it comes to shock. Over tightening or dropping a catalyst with the sensors still in it will waste them for sure. Other than that I've never seen all the AJ16 sensors needing to be replaced at once. Who/how was that determination made??
Old May 20, 2011 | 10:46 PM
Christian 96 XJR's Avatar
You can get them for about $60-$80 from Amazon or Rockauto.com
Old Jun 18, 2011 | 02:00 PM
genoaz's Avatar
I havea 1995 xj6 w/ 183k miles on it , i changed the 2 closes to the eng, there easy, bought mine at NAPA auto parts, there were NGK's problably made for bousch. going to change out the back soon, that will take some time wires route behind engine. had some "Check engine lite" issue, so that was one of the thing i chaged alone with EGR valve, new plugs, new ingnition boots from ingnitions coils.
Genoaz
Forcedair1
Sep 8, 2025 01:57 PM
Forcedair1
Feb 19, 2020 01:51 PM
vwbusbits
Oct 13, 2015 03:43 AM
cman3000
Aug 5, 2009 03:49 PM
