xjr6 auto gear box
Old Oct 3, 2008 | 01:44 PM
Brutal's Avatar
Default RE: xjr6 auto gear box
GO HAVE CODES CHECKED, #1 FAULT FOR THIS TRANS MESSAGE IS THE TPS(THROTTLE POSITION SENSOR) ON THE THROTTLE BODY, IF IT DOES KNOW THE THROTTLE POSITION IT DOESNT KNOW WHERE OR HOW HARD TO SHIFT.
Old Oct 7, 2008 | 08:27 AM
cool's Avatar
preventive maintenance, change transmission fluid and filter every 15K to 20K miles.
Old Oct 8, 2008 | 05:38 PM
AJ16er's Avatar
ORIGINAL: cool
Either that or most likely the fact that the XJR and XJ12 X300s have a GM transmission. GM is synonumus with unreliablejunk.
Old Oct 8, 2008 | 09:34 PM
oldmots's Avatar
A common cause of this fault in the XJR6 is a worn rear tranny mount which damages the too-short wiring harness to the TCM by pulling the wires out of the pins, giving all kinds of strange operational problems. Do a pin out test of the harness to be sure, it is expensive to replace and a used one is probably not a good investment. The repair is a new harness and mount.
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
1964Daimler
Oct 3, 2015 12:18 PM
Tipptone
Sep 16, 2015 07:39 AM
arnoldmilk
Sep 3, 2015 07:42 PM
