yet another AC issue
Old Jun 3, 2013 | 06:27 PM
avioni's Avatar
Default yet another AC issue
so the AC compressor is working and blowers are working but for some unexplicable reason the passenger vents do not push cool air or i should say the driver vents push cooler air than the passenger vents. WTH!!!! also overall it is not really cooling like it was before. altho it sometimes feels like it is then a few minutes later it feels like its not. the system is full of gas and the compressor is working as it should. any ideas? this time logic doesnt work for me lol.
i tought about blocking off the heater hoses since i live in tropic and there is no need for that. but i want to do that not thinking it will fix the issue, i just want to do it cause its not needed and just maybe it might make ac a bit cooler.
Old Jun 3, 2013 | 10:40 PM
Doug's Avatar
The climate control has a self-diagnostic capabilty that might be helpful here.
-Ignition off
-Press and hold "Auto" and "recirculate" buttons simultaneously
-Turn igntion on
-Display will flash
-Press "Auto"
-Press the "Face" button to scroll thru the codes
-Any code accompanied by a beep is a current code. No beep=history code
-If "0" is displayed there are no codes. Wait 30 seconds for self test.
-To clear codes press rear defog and "face" buttons simultaneously
-Turn system off, then on again, to leave diagnostic mode
Let us know if there are any codes!
Old Jun 3, 2013 | 11:03 PM
avioni's Avatar
Beaitifull thanks. I got stored codes 23 and 24 . Beeping code 12. After clearing codes I still get beeping 12 code but no longer get 23 and 24
Old Jun 4, 2013 | 12:16 AM
Doug's Avatar
#12 is ambient temp sensor open circuit or short circuit
#23 is refrigerant pressure switch open circuit of short circuit
#24 is face vent demand potentiometer open or short circuit
The 12 code may explain poor cooling but I don;t se how it would be realted to an air distribution problem
Hopefully others will chime in
Old Jun 4, 2013 | 09:25 AM
avioni's Avatar
The ambient temp sensor where is it located? Wouldnt it only affect when the ac is in auto mode? I always have it on manual mode coolest setting.
The refrigerant pressure switch. That could also be the issue I suppose. if it where intermitent. Im assuming thats the 4 wire switch on the refrigerant line close to the refill plug. Maybe I could bypass the switch for testing purposes. I looked at diagram and I see it has two switches internally. Should I just bypass both?
Old Jun 5, 2013 | 04:49 PM
avioni's Avatar
Checked again today and got beeping code 12 and 23 then not beeping code 44
Old Jun 5, 2013 | 08:49 PM
Doug's Avatar
I've never had to delve into my climate control (knock on wood) so I'm afraid I can't pass along any troubleshooting tips.
Hopefully someone will come along who know something.
Old Jun 7, 2013 | 02:53 PM
avioni's Avatar
i got expansion valve diagnosed. where is the valve on the 1997 xj6? when engine accelerates the air pressure drops near 0. is there any DIY guide on this?
Old Jun 8, 2013 | 05:28 AM
mikesmith2's Avatar
If were me I would get a local specialist to take a look.
They can pressure test etc then give you a better diagnosis.
In the UK mobile technicians charge £60 for a complete service and recharge
Old Jun 8, 2013 | 07:10 AM
avioni's Avatar
thats what the specialist told me. high side pressure high , low side pressure drops when accelerating. with that he concluded the expansion valve was bad.
Old Jun 8, 2013 | 07:54 AM
mikesmith2's Avatar
You will need to get them to replace it so that the gas is kept then put back into the system
Old Jun 8, 2013 | 07:14 PM
avioni's Avatar
I read the expansion valve is part of the evaporator on our cars and the entire unit needs repacement????? Please tell me this is not true.
Old Jun 9, 2013 | 02:41 AM
mikesmith2's Avatar
This may help find the valve
File Type: pdf
Old Jun 9, 2013 | 08:40 AM
Doug's Avatar
Out of curiosity I did some brief research on this.
1) In the Jaguar catalogs there is no listing for an expansion valve as a separate item. So, it appears that the only way to buy it from Jaguar is to buy an evaporator.
2) Some have said that the expansion valve is "integral" to the evaporator.
However.......
3) Various aftermarket vendors list the expansion valve as a stand-alone item.
4) At least one person says the expansion valve is on the cabin-side of the firewall and looks like a machined aluminum block....which matches the pictures seen in the aftermarket listings.
Hopefully some dealer techs or someone who has been there, done that, will chime to to clarify.
My conclusion, perhaps wrong, is that A) the expansion valve *can* be replaced, B) *Jaguar* does not service the expansion valve separately and C) aftermarket vendors sell the valve separately.
<shrug>
Old Jun 9, 2013 | 07:50 PM
avioni's Avatar
Yes i saw the aftermarket aluminum block with what looks like a clip u can pull on the side.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
carelm
Sep 5, 2015 01:13 AM
