$20 Fog Light Replacement
Old Oct 25, 2010 | 08:22 PM
Sinister 1's Avatar
Default $20 Fog Light Replacement
After getting my XJ8 repainted I just could not bring myself to bolting the sandblasted fog lights back on. After checking on the OEM prices I then started looking at the aftermarket. Since the factory fog lamp mounts directly to the fascia, I could not figure out how to mount aftermarket lights without having to fab up brackets.
Then in a moment of clarity I figured it out.....
Here's what I started with.
Old Oct 25, 2010 | 08:44 PM
Sinister 1's Avatar
Default A real Hatchet Job
I found a set of 3.25" round lights and decided to use the old fog light body as the mount.
Here's how I made it work....
1. Whacked the lens with a chipping hammer to break it.
2. Picked the glass pieces from the edge.
3. Took a bunch of measurements to line up the light.
4. Drilled mounting holes in the old reflector.
5. Bolted in and squared up the new light assembly.
6. Reinstalled the fog lamp in the Fascia.
7. Spliced into the factory wiring.
The fit in the hole is perfect and the lamp can be aimed using the factory adjuster.
For those that have deeper pockets a higher end lamp can be used.
Attached Thumbnails  Fog Light Replacement-hatchet-job-1.jpg    Fog Light Replacement-test-fit-1.jpg    Fog Light Replacement-gutted-1.jpg    Fog Light Replacement-final-1.jpg
Old Oct 25, 2010 | 09:07 PM
Looks like a decent job sinister...from someone using their head to work around a problem
good looking finish....thanks for sharing
Old Oct 25, 2010 | 09:54 PM
JaguarXJR02's Avatar
that looks very good and the new paint job looks to be nice as well
Old Oct 25, 2010 | 10:09 PM
Brutal's Avatar
Is that DIRT I see in the paint
Old Oct 26, 2010 | 07:59 AM
Sean B's Avatar
good work, I need to do this same job. Where did you find the lamps?
Old Oct 26, 2010 | 03:18 PM
Sinister 1's Avatar
Nope. The car was kind of dirty though....
Old Oct 26, 2010 | 03:35 PM
Sinister 1's Avatar
They are the Optronics QH-85BD Kit. I got mine at...
http://www.oreillyauto.com/site/c/de...0393&ppt=C0335
I think they are available all over the internet also.
X_Type_South_Africa
Dec 9, 2015 05:37 PM
gene1
Sep 3, 2015 08:04 PM
Aranon
Sep 3, 2015 07:56 PM
Jandreu
Aug 29, 2015 07:31 PM
gene1
Aug 27, 2015 09:35 PM
