01 XJR Battery dead, keys won't open trunk
Old Nov 23, 2012 | 11:58 AM
Porsche407's Avatar
Exclamation 01 XJR Battery dead, keys won't open trunk
Hi, tried to review the posts for a solution but my car only has the 2 holes that hold the license plate on. Anyone have a pic or diagram where I can see where to jump it from under the hood or any other solution would be helpful!
Old Nov 23, 2012 | 12:18 PM
Dinger's Avatar
There's a positive terminal on drivers side of the engine covered with a rubber cap. Jump leads from a 12v source, positive lead to this terminal, negative lead to good earth, chassis is best. If it doesn't work first time, look for a better earth connection.
Old Nov 23, 2012 | 12:28 PM
Porsche407's Avatar
Arrow
Going to give this a shot now!
Old Nov 23, 2012 | 12:59 PM
kenncl's Avatar
Default Back seat fuse boxes
You can also jump it at fuse boxes under
back seat. The large black wire is POSITIVE and ground to brackets.
Old Nov 23, 2012 | 01:18 PM
Porsche407's Avatar
Didn't seem to work
Old Nov 23, 2012 | 01:20 PM
Porsche407's Avatar
Going to try this next. Thanks Kenncl
Old Nov 24, 2012 | 04:16 PM
SuperSport's Avatar
Default Positive Post and Key Hole
Probably a silly post, but I'm guessing the 1999 and 2001 are different in this respect? I've actually got a keyhole on the left of the XJR Emblem for the trunk.
And just for future, here is the Positive Post under the hood. I use this to connect a battery charger for my RC Airplanes and Heli's.
Attached Thumbnails 01 XJR Battery dead, keys won't open trunk-wp_20121124_001.jpg   01 XJR Battery dead, keys won't open trunk-wp_20121124_002.jpg   01 XJR Battery dead, keys won't open trunk-wp_20121124_003.jpg
Old Nov 24, 2012 | 04:31 PM
Ipc838's Avatar
SuperSport,
does your car have CATS suspension?
Old Nov 24, 2012 | 04:50 PM
SuperSport's Avatar
Originally Posted by ianclements
SuperSport,
I always believed it did, but I don't see any wires leading to the suspension, so likely not???
Old Nov 24, 2012 | 08:14 PM
sparkenzap's Avatar
If the underhood post does not work, you have some problem besides low battery. It is the positive lead. The chassis is the negative lead. Jumping there is exact;y like being on the battery.
Old Nov 25, 2012 | 08:25 AM
Porsche407's Avatar
Default Got it
Thanks to everyone for the help! Found the terminal and tried jumping it again. With a GOOD ground it roared to life. Next problem... ran it for 10 minutes then turned it off for 30 seconds hit the key again and it started running thru the diagnostics and died. Any ideas? Cables look new
Old Nov 25, 2012 | 08:27 AM
Porsche407's Avatar
Thanks Dinger, worked with a GOOD ground!
Old Nov 25, 2012 | 08:32 AM
Porsche407's Avatar
Thanks SS, I'll keep that in mind for my car and boat! btw key slot is the same it's just all 3 of my keys would go in and turn it but not open it! Popped immediately with motor running!
Old Nov 25, 2012 | 09:48 AM
johnleavitt's Avatar
The valet key, likely green, should not work in the trunk. The others should. If they don't, the lock is either broken, or your keys were all copied from the valet key.
Old Nov 25, 2012 | 09:58 AM
SuperSport's Avatar
My guess would be bad cable connection or bad battery, at least to start with since it'seasy to check. Even if the cables look good, I'd remove and clean them, then try to charge battery and see if that helps.
Old Nov 25, 2012 | 10:09 AM
jchavez76's Avatar
Charge and test the battery is a good start. Is the car's charging sytem working? BTW the license plate holes that you needed should be under a nice piece of what seems like black tape. They are where the lower license plate screws would screw into if it had them. Hard to see. You have to poke through the tape or peel it off. At least that's where my '98 VDP had them.
Old Nov 25, 2012 | 01:30 PM
Ipc838's Avatar
Super Sport, there should be a black, cone-shaped
cap over the shock towers if you had CATS. also
little wires running out. Maybe a previous owner
made the switch over to normal shocks.
Congrats on winning a hood liner!
Ian
Old Nov 25, 2012 | 03:35 PM
SuperSport's Avatar
Ian
Yeah, I'm excited about the hood liner, and no, I don't have those on my shocks.
Old Nov 25, 2012 | 05:45 PM
Dinger's Avatar
As your battery was completely dead, the computers will have to re-learn everything, so get her running again, with preferably a NEW battery and go for a 30 minute drive, all should be good after that. These cars are particularly sensitive to partially discharged batteries and can throw up all sorts of error codes so just get a new battery and all should be good.
Old Nov 25, 2012 | 06:05 PM
plums's Avatar
You'll be posting some pics then?
Forcedair1
Sep 8, 2025 01:57 PM
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Charlene n John
Sep 28, 2015 06:01 AM
