01 xjr bolt pattern
Old Jun 10, 2010 | 02:51 PM
greenbeast01's Avatar
Default 01 xjr bolt pattern
will these 18 fit my 01 xjr??
4 - 18" SSR GT3 wheels
Front Wheels:
18 x 8.5
+43 offset
Rear Wheels:
18x10
+24 offset
Bolt Pattern 120/5
Old Jun 10, 2010 | 03:18 PM
SteveM's Avatar
http://www.1010tires.com/WheelOffsetCalculator.asp
The bolt pattern should work, although the Jag's pattern is 120.65mm X 5.
Are those wheels for a BMW?
Old Jun 10, 2010 | 03:47 PM
they are off a bmw.. will they fit my xjr.. even with the tires??? with no rubbing??
Old Jun 10, 2010 | 05:46 PM
steve11's Avatar
ud
I'll leave the offset and fender question open, but address the bolt pattern. Owning both Jaguars and a BMW, the .65mm is a "problem". Also, both these wheels rely on a hub-centric centering system, but they are different. Even if you can get the hub-centric part working, you don't want to try to "crunch" the .65mm bolt pattern difference.
If you just have to have these, and the offset/fender clearances are answered by someone, the only correct way to do these is to have a spacer machined with the correct bolt on pattern/hub for the Jaguar, but with studs pressed in on a different circle pattern and hub shoulder machined in for the BMW wheel needs.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Matei Dima
Oct 8, 2015 11:45 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
