02 jag xj8 jack stand points
Old Mar 23, 2020 | 09:52 AM
  #141
Mrjay622's Avatar
Hi guys.
I'm back at it ..
Got a question about these variable cam spit washers , can someone tell where they go? I'm thinking under the front cam caps?
jay
Old Mar 23, 2020 | 11:04 AM
  #142
Mrjay622's Avatar
Default For get that last post I found it.
Found it ...
Old Mar 23, 2020 | 03:12 PM
  #143
Mrjay622's Avatar
More Questions!
To those that have done this before can you Please tell me where these seals go.. I know where the Crankshaft seal goes but there is also 3 other smaller ones...
I have 3 of these little guys..
thank you
Jay
Old Mar 23, 2020 | 04:59 PM
  #144
Carnival Kid's Avatar
The XR81139 is the very narrow o-ring that goes inside the harmonic balancer. (item #2 in the above image)
The KSC145624 is i believe only for the earlier A26 style timing cover and/or the SC engines without VVTs, (Item #5 in the above image) I don't believe it is used on your NA A27 motor.
The KSH108624...............is listed as the engine oil dipstick seal (item 22 in the above image)
Old Mar 23, 2020 | 05:21 PM
  #145
Mrjay622's Avatar
Thank you..
The KSH108624 is labeled as:
I can see the harmonic balancer O-Rings oil seal now. Thanks
Any idea what these are for? I have 3 of them.
Old Mar 23, 2020 | 05:37 PM
  #146
Originally Posted by Mrjay622
Thank you..
The KSH108624 is labeled as:...............VVT seals
Any idea what these are for? I have 3 of them. (4526553)
Both seem to be the same item, and are shown in this diagram......but from what I can make out it seems they are for the later 4.2 and 4.4 engine
Old Mar 23, 2020 | 07:34 PM
  #147
Mrjay622's Avatar
Thank you CK...
Almost ready to start taking the intake off..
What Fun this has become....ugh!
Old Mar 23, 2020 | 07:50 PM
  #148
Mrjay622's Avatar
Thank you CK...
Old Mar 23, 2020 | 08:01 PM
  #149
Thank you CK...
LOL, it will all be worth it in the end. Don't forget that intake manifold walk-thru that I posted, and be sure to replace the feed and return heater hoses while you are under there, as well as the notorious 3-way connector. Be sure to retain the original self-clamping hose clips on the heater hoses as they are inaccessible afterwards and cannot be checked for tightness like regular screw-type hose clamps.
Pity you are so far away because we could have a celebratory beer over this when it is all done!
CK
Old Mar 23, 2020 | 09:24 PM
  #150
Highhorse's Avatar
If you drive almost 70 miles due south MJ, you'd be right where I grew up on the PA/NY border.
Old Mar 25, 2020 | 12:06 PM
  #151
Mrjay622's Avatar
Hey Highhorse / CK
Are you saying your a Redneck country guy...
I grew up in the Bronx Stupidity bought me up here... ( Looking for that so called better life )
Had enough of that doggie doggie life, Everyone looking to screw the next person over just to get ahead... Dont get me wrong I miss living and working in NYC I miss the Food and Normal size women..Oh and the pay scale.
Boy was I far off the mark with that idea. .lol
Well this is where I'm at with looking for good Jack stand locations to work safely on the Wheel studs and Brakes
What a mess.
Old Mar 25, 2020 | 12:46 PM
  #152
Yep, looks about right to me!
Old Mar 25, 2020 | 01:59 PM
  #153
Mrjay622's Avatar
Yeah ..
Made me scratch my head I wonder how did I get here!
From a misfire that seem to go away for a while after cleaning out the oil from the sparkplug wells to this... I knew the cam covers needed a new seal kit. . Ez ez job....
Oh well gone this far I guess I'll keep going and see where it leads.
Old Mar 25, 2020 | 02:10 PM
  #154
You have the new heater hoses and 3-way connector?
Old Mar 25, 2020 | 02:14 PM
  #155
Mrjay622's Avatar
Looking ip the hoses right now.. ...
and why I have so much oil in the intake manifold.
Old Mar 25, 2020 | 04:44 PM
  #156
Highhorse's Avatar
Yeah, grew up around 3 farms....worked them all, shot and killed about every animal around in the hills. Joined the AF to get away and travel and I get stuck in Minot ND my whole tour, ...damn that place sucks.
Sorry to say to ya, I really despise Manhattan and the surrounding area, everything is taxed to death and nothing gets fixed, ...plus I'm not a fan of Unions. Love going out on LI and taking the fairy out of the Point over to New London.
I can say your way more mechanically inclined than any NYC'er I've come across. Most cry simply about driving.
Old Mar 25, 2020 | 05:05 PM
  #157
Mrjay622's Avatar
Hi HH
Well I learned from my Cuban mother and Italian dad . Before you pay someone to fix anything try and figure it yourself.
I always enjoyed working on cars and everything else that was my therapy.
I guess if your born and live in a big city you just get use to it . It was my home.
As far as taxes they are no different than here in upstate NY expect the pay was 2x+ better working in the city...
Live and learn....
Old Mar 25, 2020 | 05:08 PM
  #158
Mrjay622's Avatar
What's the trick to disconnecting heater hoses 3-way connector?
Old Mar 25, 2020 | 05:47 PM
  #159
From what I remember there was no trick, just release the tabs and insert the new one.
Old Mar 25, 2020 | 07:46 PM
  #160
Mrjay622's Avatar
I been trying doesn't look like it wouldn't take much to break it or ruin it..
Maybe in a little bit I try a little heat , the normal areas of using a piece of 10 gauge wire or 2 small screwdrivers just isn't working.
unless there is a 3rd spot I don't see to pry up on.... ill keep at it....
