02 XJR abs trans problem
Old Sep 28, 2010 | 12:39 PM
protech's Avatar
Default 02 XJR abs trans problem
Well here's a new one, I had an ABS mod go out so I decided to repair it as per forum instructions took it off sure enough the solder joint was bad resoldered it put unit back on. That wasn't it, still had abs message but now have following messages: 1. low brake fluid 2. incorrect part fitted 3.ASC . Now have amber engine light, trans stuck in first gear and a red brake light and no speedo. Brake fluid level fine. At no time did I touch anything with the trans. Also disconnected neg. on battery for 10 min to clear codes, have done this before and never had trans problem. Checked codes there are as follows: 1121, 1637, 1720 checked these on forums but no joy any ideas?
Bob
Old Sep 28, 2010 | 01:39 PM
H20boy's Avatar
Did you have to cut the ABS module apart to access the bad solder joint?
Old Sep 28, 2010 | 01:56 PM
Sean B's Avatar
sounds like it doesn't like the abs module, did you disconnect the battery when you pulled it? Have you checked the wires and connection? try reseating it and clean contacts with a contact cleaner. Make sure the battery is disconnected. Also make sure the battery is fully charged.
Old Sep 28, 2010 | 05:14 PM
protech's Avatar
yes cut unit apart resoldered did not use too much heat or over solder.
Did disconnect battery.
Guess I'll install used unit and see.
Called around dealers and rebuilders still haven't got the definitive answer, are these units programmed to the car??
Old Sep 29, 2010 | 01:10 PM
Sean B's Avatar
yep
Old Sep 30, 2010 | 12:08 AM
pdog2000's Avatar
if the units are programmed for the car and if I buy a used unit for the car how do I get it programmed
Old Sep 30, 2010 | 04:49 AM
Sean B's Avatar
either main agent or independent with the IDS software....it'd be wise to try and diagnose the issue first, have you got anyone near you that can pull codes from the abs module, again a good indi? I saw the warnings you have when I put an abs pump on my car that wasn't it's own, and swopped back to the original to have all warnings go. My thought is the your car thinks its not its own pump after the work and refit, which could be a number of things, like I suggested, bad connection, wiring fault. If you say it's correctly fitted and repaired, then its a case of getting the codes pulled from it.
Old Sep 30, 2010 | 06:38 AM
protech's Avatar
put in a used unit it worked fine, no programming needed.
Figured out what caused all the problems, while cutting the unit open with a coping saw, the blade slid into the unit. This must have raked across the various solder points either shorting or carrying a staitic charge into the unit and corrupting any info. Moral of the story don't use a coping saw and use a hacksaw like those who've done it. Thanks for your input.
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
pocketrocket
Sep 3, 2015 07:44 PM
innzane
Sep 2, 2015 10:08 AM
