03 XJR Left front seat switch
Old Aug 6, 2022 | 06:28 PM
dmpsqrd's Avatar
Default 03 XJR Left front seat switch
An (albeit brief) search failed to address my issue. The L front seat will only move if I use the memory buttons in the door- nothing from the switch on the side of the seat. My issue is that currently- the seat doesn't raise high enough above the sill to remove the switch in order to check the continuity.. Should I bite the proverbial bullet and remove the seat (altho I suspect that's easier said then done with the seat in it's current position)...TIA to the group!
Old Aug 7, 2022 | 09:25 AM
Highhorse's Avatar
Much easier to simply remove the nuts from the rails and lean the seat back, pick up the steering up though. With the limited space, considering your seat position, you should be able to prop it up to get to the electronics. Though it may be an acrobatic moment.
Dave (good dude) at everydayXJ.com did have a switch a couple weeks ago, but apparently sold it. But he does have the drive motors if you find any of those bad (bottom of page)... https://shop.everydayxj.com/category_s/1950.htm
You can email him and inquire, he responds fairly quickly.
Here's another site I've used in the past... https://www.jaguarpartsspecialist.com/new-category-132/
...and this is from the X308 Workshop Manual...
Old Aug 7, 2022 | 10:58 AM
dmpsqrd's Avatar
Thank you sir.... sounds like fun since the seat positions in the "memory" are fully down.... hoping for a switch and not a module...
Old Aug 7, 2022 | 02:31 PM
Col. Sandurz's Avatar
I've got all the parts if you need them.
Old Aug 7, 2022 | 03:12 PM
dmpsqrd's Avatar
Stay tuned... I've got a seat to unbolt and THANKS!
Old Aug 7, 2022 | 03:44 PM
Addicted2boost's Avatar
I’ve encountered on numerous times where the wire(s) break on the backside of the switch specifically because the seat foam collapsed and the wires rub through the seat bottom frame and blow a fuse.
Old Aug 8, 2022 | 08:44 AM
dmpsqrd's Avatar
Thanks- I suspect it's the switch... as soon as it stops raining...I've got some contortioning to do...
dmpsqrd
Apr 25, 2022 10:21 AM
steve12955
Mar 23, 2015 08:20 PM
sparkshaneman
Mar 3, 2011 05:00 PM
SRL1990
Apr 26, 2010 11:47 PM
martyXKRuk
Oct 1, 2008 05:52 PM
