0XJ8 72,000 miles fail/safe mode
Old Mar 3, 2014 | 01:36 PM
protech's Avatar
Default 0XJ8 72,000 miles fail/safe mode
Gentlemen;
Local minister asked me for help on the above Jag. While driving he gets a failsafe mode and or restricted performance message,however, car DOES NOT lose power drives just fine! Also cruise control does not work, ran codes a small evap code and a P1111 other then that nothing.
Battery and alternator checks out ok.
Any ideas?
Old Mar 3, 2014 | 01:45 PM
flay's Avatar
Generally these messages are linked to throttle body, but this is not the case; it may be the brake pedal switch, have you tried without the cruise control on?
Old Mar 4, 2014 | 12:55 AM
margate69's Avatar
P1111 is a code that means it has run the monitors for the catalyst, evap etc. etc. Just an OBD2 compliant code.
How often does it happen, give me the other code numbers, we'll solve this in a quick minute.
Old Mar 4, 2014 | 11:39 AM
protech's Avatar
The only other code was for a small evap leak I don't remember the code think it was PO441?
Forcedair1
Sep 8, 2025 01:57 PM
aholbro1
Dec 29, 2024 06:46 PM
vsol
Aug 29, 2018 09:46 PM
08Z06
Oct 24, 2015 05:46 PM
Numwen
Sep 6, 2015 12:30 AM
