1998 Jaguar xjr Alternator Charge Light
Old Jul 25, 2012 | 07:20 AM
Kev10001's Avatar
Angry 1998 Jaguar xjr Alternator Charge Light
I have the charge light on all the time on the dash and display saying not charging. This is what i have done so far.The battery is charging checked with my multi meter.
1:New Battery - Light still on
2:Used good alternator -Charging light still on
3: Checked correct voltage at pin 2 on multiplug - OK
I have unpluged the multi plug from alternator (generator) and the light still stops on . Is this correct as i believe the alternator supplys the charge light with a feed?
If any one has any ideas please let me know as its really bugging me
Thanks in Advance Kev
Old Jul 26, 2012 | 08:21 AM
jimlombardi's Avatar
Hi Kev
Your problem maybe in the wiring harness from the Generator to the Instrument Pack's Warning light.
Here is a JPEG file showing the 2 wiring diagrams -
Fig 03.2 Generator's Regulator, Suppression Module, ground and wires color coding (wire coloring for wire going to warning light is Slate with White stripe)
Fig 08.1 Instrument Pack, Generator charging warning light, wiring from Fig 03.2
Here is the Wiring Diagram from the Ignition Switch to the Generator (shows Engine Compartment Fuse Box wiring):
Jim Lombardi
Old Jul 27, 2012 | 06:04 AM
Kev10001's Avatar
Thanks Jim,
I removed clocks checked wiring and also removed the plug alternater cleaned terminals and resoldered plug.
Now charge light is working as it should be !
NOW on to next fault !
BrentGardner
29
Dec 16, 2024 12:13 AM
aquifer
Aug 29, 2015 04:54 PM
BlacXJRcat
Aug 28, 2015 07:10 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
Zues
Aug 27, 2015 12:02 AM
