1998 xj8 wont start
Old Feb 23, 2010 | 09:13 PM
ac4.6gt's Avatar
Default 1998 xj8 wont start
hi i have a 98 xj8 L with 140k in the clock. Car had been sitting for about 2 months cause it was leakin rad fluid out of the top thermostat housing plastic piece cause of a crack. So we just had it replaced and on the way home the car just cut out and the low coolant light came on and oil pressure code came up and now the car will start for 2 sec and cut out. checked the oil and no sign of anti freeze and the tank was full but its empty again. i thought it was a head gasket but i dont know now......any tips? or where i should start?
Old Feb 23, 2010 | 09:35 PM
sparkenzap's Avatar
you know, you MIGHT not have much of a problem. The stall can cause the oil pressure indication and it MIGHT have been from some connector not put back together right. The low level could just be a result of the system burping. That analysis is based on your statement that no coolant was in the oil. Then again....
Old Feb 23, 2010 | 09:40 PM
ac4.6gt's Avatar
i hope soo...im gonna jump into it tomm and see.....any other input?
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Rlover
Mar 30, 2016 10:04 PM
arnoldmilk
Sep 3, 2015 07:42 PM
