1998 XJ8L Trunk button not working
Old Jan 26, 2013 | 02:22 AM
98JagXJ8L's Avatar
Exclamation 1998 XJ8L Trunk button not working
Keyless trunk release does not work, button inside vehicle driver side does not open it either, only way i can open it is with the key. i bought the car like this.
when pressing the buttons inside or outside trunk button, i dont hear anything, is there a fuse to this i can check?
i would love to get it working again.
Thanks in advance guys!
Old Jan 26, 2013 | 04:35 AM
Sean B's Avatar
It's controlled by the body control module - there's a common fault with the wiring to the right hand boot hinge, it snakes into the trunk panel, opening and closing action over time cracks and splits the wires. You've to eyeball each wire individually by stripping back the loom tape to check. The wires might not have an obvious break so thin or weak looking wires need cut and rejoin. It may also be a faulty switch, but check the wiring first.
I found a black wire on mine, soldered/shrink tube and got it working.
Hope this helps.
Old Jan 26, 2013 | 07:14 AM
steveinfrance's Avatar
You can often find a broken conductor strand inside intact insulation by gently stretching the wire. You'll see the insulation 'neck down' at the break.
Obvious, I know.
Old Jan 26, 2013 | 02:02 PM
98JagXJ8L's Avatar
Thumbs up
i will get on that right now and take photos of what i find thanks guys!
Old Jan 27, 2013 | 08:16 AM
John Miller's Avatar
hi i also have the same problem on my 98 xj8, so will check out the wires , many thanks
john
Old Jan 29, 2013 | 01:06 AM
98JagXJ8L's Avatar
Looked at all the wires and they seem to be looking fine, and so does the #10 10amp fuse in the trunk... Im figuring it could be the button mentioned earlier,
still investigating, i could not get a good pick of the wires on the latch, but they all seem fine,
:P
Attached Thumbnails 1998 XJ8L Trunk button not working-96974d49-9e75-4d75-b6c3-091d52e9aafd-1726-0000011d3c7ab8fe.jpg   1998 XJ8L Trunk button not working-7c7a43a2-7131-4f6a-9411-a65267d9dbd5-1726-0000011d4236feed.jpg
Old Jan 29, 2013 | 03:26 AM
jimlombardi's Avatar
Here is another current forum thread with electrical issues concerning the trunk lid that may be of some help with your trunk release problem (look at post# 2):
https://www.jaguarforums.com/forum/x...-lights-88876/
Jim Lombardi
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
philwarner
Sep 5, 2015 10:05 AM
arnoldmilk
Sep 3, 2015 07:42 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
