1998 XJR airbag light is on
Old Jun 20, 2008 | 05:58 PM
JagtechOhio's Avatar
Default RE: 1998 XJR airbag light is on
Quick and dirty answer, maybe you will get more in depth responses with patience.
Not related to battery, after trying the hard reset as he did.
Not likely to show up on his code reader, unlesshis is Jaguar specific.
Sometimes identifiable by adjusting the steering wheel: I had one with an undiagnosed fault(at customer request) which I could correct the warning by moving the steering column adjustments to "full up" and "full in". Any other position, the warning light would illuminate. Possible harness connection or cassette reel on the column.
Search archives here, I believe FactoryJagTech or jag_genius have discussed SRS faults in the past, seat sensor wiring being among the topics. If you find their information, please thank them for it.
Old Jun 20, 2008 | 06:05 PM
jag_genius's Avatar
if it was a jag reader.. and had no codes then it probably needs a casette reel
Old Jun 20, 2008 | 06:15 PM
Hey _genius,
If you haven't done so yet, please have a look at the Rat 427 posts and the threads connected to them. I'd be interested to read your comments if you have any you'd like to share.
Thanks for sharing a piece of your turf, your knowledge and yourgood will in the past. Best of luck in future endeavors,
Andrew Bernstein
British Auto Care
Old Jun 21, 2008 | 12:06 PM
FactoryJaguarTech's Avatar
If no codes coming up with scanner, you need to disconnect something in the system. Easiest is passenger airbag. Cycle the ignition with it disconnected. You will then see 2 codes. 1 for passenger airbag open circuit and the other for whatever the original problem is.
My bet is on the drivers seat harness.
Old Jun 25, 2008 | 05:56 AM
Seat belt pretensionsr is the pyrotechnic device in the seatbelt.
2 possibilities- Bad seat belt or bad seat wiring harness.
Old Jun 25, 2008 | 12:08 PM
KAZsam's Avatar
I would be hesitant on using this "mechanic" seems like he does not know anything.You have to find out all the answers for him. My Tech. has books and CD's at his shop for reference to repair anything on a Jag. If I had to ask around for him what good would he be?
Old Jun 26, 2008 | 07:11 PM
The harness is part of the body harness. Likely it is the seatbelt.
Jpav27
Jul 31, 2022 06:43 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Rlover
Mar 30, 2016 10:04 PM
XJsc-guy
Nov 23, 2015 01:56 PM
AL NZ
Sep 4, 2015 08:39 PM
