1999 Jaguar XJ8 not starting
Old Jul 25, 2013 | 11:31 PM
rpolizzano2013's Avatar
Unhappy 1999 Jaguar XJ8 not starting
Hey guys, so unfortunately my jag has stopped running. And my problem is, well, I'm not entirely sure why.
About two months ago is when I first began noticing problems. It would have a bit of a rough idle at times (especially at startup), and it also had constant slight engine noise that could possibly be a misfire (I'm not entirely sure however). Also my check engine light is on and restricted performance comes up on the dash.
One day I drove to the store and it stalled out on me on my way home. I shut it down and restarted it and I received the same rough idle, engine noise as usual, but it started and I drove it home. When A few hours later after I drove it home, I tried to start it up again. This time however, it would crank, turn over but then stall out right after. Now it cranks but doesn't turn over at all. I only keep hearing a kind of a "whirring" sound (Best way to describe the noise ) whenever I try to start it. I'm completely lost about what the problem could possibly be, any help would be greatly appreciated, I really hope you guys could help me out!
(By the way, I just had a tune up done on it (oil, air filter, spark plugs, etc.) and also replaced the fuel pump, fuel strainer, and fuel filter.)
Old Jul 25, 2013 | 11:58 PM
MoscowLeaper's Avatar
If the starter is working (whirring sound) and engine is not turning over - then it's a problem with a starter motor/solenoid. Repair/replace, check codes and come back
Old Jul 26, 2013 | 08:34 AM
JimmyL's Avatar
Could also be cylinder wash, if the engine is actually turning over. You should get a scanner too though. You can't just keep driving around with a check engine light on and restricted performance. I don't mean to sound preachy, but you don't want to get stuck on the side of the road somewhere.
Old Jul 26, 2013 | 03:32 PM
Ok, so I just broke out the OBDII scanner and it threw me these codes/messages:
P0171 - Bank 1 system too lean
P0174 - Bank 2 system too lean
P0453 - Evaporative emission system pressure sensor/switch high input
P0455 - Evaporative emission system leak detected (gross leak/no flow)
P1000 - DTC definition not found. See service manual.
Any possible suggestions?
Old Jul 26, 2013 | 04:25 PM
XJRChad's Avatar
Have you checked your air intake for oil? My XJR was stalling right after start-up. The air intake was full of oil, due to a clogged part load breather. I cleaned the breather and the intake, and it was much improved. I know this won't help much with your no-start issue, but maybe it may help with your rough/no idle issue.
Old Jul 27, 2013 | 01:50 AM
Well,you have a huge vacum leak. Check EVAP and all hoses ( breathers and so on) under a hood.
Old Jul 27, 2013 | 08:14 AM
JimmyL's Avatar
You might also have cylinder wash. There are a lot of threads about it on here. Basically, your oil film has gone and you need to prime the cylinders with a little bit of oil to get compression. Good luck.
Old Jul 27, 2013 | 12:08 PM
I was actually suspecting cylinder wash, I've seen a few other people on here talk about how cylinder wash was the problem with their jag all along. I'm going to try to fix that and see where that gets me.
Old Jul 27, 2013 | 12:56 PM
Maninahat98's Avatar
Are your spark plugs wet with fuel?...You said you'd recently changed the fuel pump? Still working, got fuel presssure, wet spark plugs etc? Allan
Old Jul 27, 2013 | 03:50 PM
Just checked my spark plugs, they were wet. I dried them off and replaced them. I also noticed that my ignition coils were rusted some more severely than others. Could this have any play in this as well?
Old Jul 27, 2013 | 06:42 PM
Also just remembered that a few months back, I lost my fuel tank cap. Could this be the cause of the "P0455 - Evaporative emission system leak detected (gross leak/no flow)" code?
Old Jul 28, 2013 | 05:08 AM
One of the really clued up guys on the forum with know this I am sure (where the sensor is located / connectors etc) . I would clear the codes on the OBD reader and retest to get latest codes if not done already.....It sounds like the
sensor is open circuit (broken wire...or you really do have a massive air leak?...) I'd go for the tracing and continuity testing the wire(s) to / from the sensor just in case.....I am not sure where the sensor is for this, but the guys on the forum will....you definitely have good fuel pressure, sure? Hope this helps, Allan
Old Jul 28, 2013 | 05:29 AM
P0455 may be a result of a lost fuel tank cap or defective fuel tank cap seal.
Old Jul 28, 2013 | 06:02 AM
........ the OBDII scanner and it threw me these codes/messages:
Systematic troubleshooting is the way to go. Read the codes, identify contributing factors such as wet plugs / missing fuel tank cap / coil condition. Note the 'Default Actions' and work through the 'Possible Causes'.
You can ignore P1000. This means OnBoard Tests have not been completed since the last memory clear. You will always see this or P1111 (OnBoard Tests completed).
The full DTC listing for the other codes is:
Faulty coils set an individual code for each cylinder so it looks like these are still OK.
Air leaks should be first on the list to check. Repeated failed attempts at starting will have resulted in neat fuel in the cylinder bores (and wet plugs). The plugs should be thoroughly dried and a few mls of oil put into the bores to counter the wash and restore compression..
Old Jul 28, 2013 | 12:01 PM
v8mad's Avatar
Hi,
I suspect you have a vacuum leak somewhere, a good place to start looking is the part load breather pipe where it enters the engine, make sure the hole is not blocked, DO NOT make the hole any bigger when cleaning it out. On the firewall in the middle is a black canister with Jaguar on the cap, this is I believe a purge valve to do with emission control. It is held on by two bolts and also has a two wire connector, remove the bolts and pull the canister forward, you will see that there are three vacuum pipes connected to it. On mine the middle smaller pipe had come adrift, this caused all sorts of warnings including engine fail safe, No ABS, No Trac etc. I repaired/replaced the pipe and the warnings stopped, the car also ran a whole lot better. It's a 10 minute job to check the vacuum pipes on the canister just to be on the safe side. I have learnt that even a small vacuum leak will cause trouble. HTH
Old Jul 28, 2013 | 12:18 PM
Jhartz's Avatar
I I am confused. The starter is running, correct? Is the engine turning over? As noted before, if it is not turning over the problem is the solenoid starter. If in fact, it is cranking but not starting that is a different set of problems. In my opinion, all of the problems that you're seeing with the code reader should not keep the engine from starting. What happened when you put a small amount of oil in each of the spark plug ports and tried to start the car?
Old Jul 28, 2013 | 09:47 PM
I tried to correct the problem of possible low compression in my cylinders (the cylinder wash situation) last night. I tried to start up the car with the accelerator completely depressed and the spark plugs out to redistribute the oil throughout the cylinders, waiting about 15 seconds per crank. However, on the 6th turn of the key, it seemed to be that my starter was no longer operating, I was only hearing a click when I turned the key. Could i have possibly killed my battery? (all the windows and other accessories still work fine in the car, i feel as if i did more damage than good..) Not sure where to go from here..
Old Jul 28, 2013 | 09:55 PM
Attachment 49449
I honestly think that the P0455 code is coming from the fact that the fuel tank cap is missing. I remember when I was siphoning the gas out of my tank in order to replace my fuel pump, the small round metal spring loaded seal at the top of the filler neck was not closing flush and there was a small visible space in between the two.
thedugger1
Sep 24, 2015 05:32 PM
1964Daimler
Sep 2, 2015 11:41 PM
Newsguy
Aug 30, 2015 11:27 AM
bigw909
Aug 30, 2015 09:29 AM
souldoubt
Aug 25, 2015 08:15 PM
