1999 xj8
Old Aug 20, 2016 | 05:56 AM
marky151's Avatar
Default 1999 xj8 massive battery drain
Hi, have a pretty big problem with a parasic battery drain, in fact huge!!, drain test shows 6.96AMPS!!!, disconnected alternator down to 4.56AMPS so still have a massive drain, had alternator bench tested and its ok, also shows ECU is still powered up when key out of ignition. HELP any ideas? Cheers Mark
Old Aug 20, 2016 | 06:18 AM
RJ237's Avatar
Check that the little flap closes when you pull the key out. It's a fairly common problem.
ohnoesaz
Dec 5, 2018 10:31 AM
yidal8
F-Pace (X761) / C-X17
Jul 26, 2016 08:16 AM
Chris starko
May 14, 2016 11:31 PM
Ronco1
General Tech Help
Apr 21, 2016 12:37 PM
thetruthc32
Aug 16, 2007 08:03 AM
