1999 XJR Oil Change Help
Old Oct 10, 2009 | 10:02 PM
jagmarine's Avatar
Default 1999 XJR Oil Change Help
I usually take my 1999 XJR to the shop to get the oil changed but after the prices have been going up (50 then 60, now 70 dollars). I will admit, I have no idea where the oil drain plug is on this car. Looking under the car from the passenger side, there is a small black "plug looking" bolt right next to the Oil Filter. I was tempted to try that one but, I have seen people drain their transmission fluid and other fluids attempting to get to the oil plug. Can someone please point me in the right direction? Thanks.
Old Oct 10, 2009 | 11:30 PM
labcoatguy's Avatar
Can you take a picture of what you're referring to? I changed the oil on my car (also a 99 XJR) and saw only one bolt there. It points slightly forwards, and it's pretty close to the oil filter, so if that's the one you're referring to, chances are that's it.
Old Oct 11, 2009 | 08:03 AM
Markus's Avatar
What you are referring to is the bolt which simply holds in place the small air deflector. Taking it out and removing the air deflector gives access to the oil filter. The oil drain plug is just towards the center of the car from the deflector bolt, same size, at the corner of the oil pan.
Transmission drain plug is way farther back on the car.
Don't forget to clean the part load breather (by running a 7/64 drill bit back and forth with your fingers in the aperture - be careful not to drop it inside the engine !!!) every time you change the oil and filter.
Cheers!
________
Old Oct 11, 2009 | 05:10 PM
jagmarine's Avatar
Default Picture of Possible Oil Drain Plug
Here are two pictures of what I'm assuming is the oil drain plug. One is just of the bolt, the other shows the proximity to the filter.
Attached Thumbnails 1999 XJR Oil Change Help-dsc01114.jpg   1999 XJR Oil Change Help-dsc01116.jpg
Old Oct 11, 2009 | 07:21 PM
Brutal's Avatar
yes thats it, and good you asked I have has to refill more than a few transmsisons after being towed in from people that thought they new what they were doing. that mistake replaces 10 oil changes once you figure labor and trans oil, plus the tow
Old Oct 11, 2009 | 07:56 PM
jagmarine's Avatar
Default Thanks
Thanks all. I have owned many American cars and I have never seen an oil drain plug so far forward on a car.
Old Oct 11, 2009 | 09:48 PM
Brutal's Avatar
well you could always go buy a Porsche is you want to really be confused
Forcedair1
Sep 8, 2025 01:57 PM
kelliott
May 31, 2022 05:26 PM
ZJag
26
Sep 5, 2016 03:33 PM
bdboyle
Sep 4, 2015 06:16 AM
pnwrs2000
Sep 3, 2015 11:55 AM
