1999 XJR questions
Old Apr 24, 2009 | 02:10 AM
rochoa21's Avatar
Default 1999 XJR questions
I'm going to go look at a 1999 XJR with about 85,000 it had the timing chain tensioner and guide replaced. The car is suppose to be in very good shape always serviced at a Jag dealership and at every 3000 miles it had an oil change. I wanted to know if $7000 is a good deal. And if there are any issues I should look out for in this current model year.
Robert
Old Apr 24, 2009 | 05:35 AM
Shotime's Avatar
I would say that's a very good deal. If at all possible, see if you can get a leak down test to eliminate any nikasil cylinder wall issues. Also, if it hasn't been done, it would be a good idea to pro-actively replace the water pump with one of the metal vaned newer models (not very expensive at all), then be prepared to proudly drive the beast, knowing people will think you're made of money. Only you will have the knowledge that you picked it up for next to nothing!
Old Apr 24, 2009 | 06:06 AM
ear-doc2's Avatar
I just recently purchased a 99 XJR that is in great shape. Body and interior was immaculate and my mechanic pronounced it to be pristine. I paid $8400. I looked at quite a few and felt it to be a good price. It had 82,000 miles and almost new Pirrelli tires. Just a great car to drive and scary fast. I would reccomend having a good mechanic check it out. Bear in mind that repairs can be very expensive. Good luck and you will love it if you get it.
Old Apr 24, 2009 | 10:26 AM
rochoa21's Avatar
Thanks for the info how much would a leak test cost regarding the nikasil cylinder wall issue
Forcedair1
Sep 8, 2025 01:57 PM
Donzi
Oct 18, 2018 12:26 AM
XJsc-guy
Sep 25, 2015 11:09 AM
jimmiejag
Sep 9, 2015 02:56 PM
philwarner
Sep 6, 2015 11:10 PM
