2 new error codes p1000 and p0455
Old Aug 12, 2012 | 09:53 AM
tilbury's Avatar
Default 2 new error codes p1000 and p0455
Just when I thought everything was going well. 2 new error codes popped up p0455 emisssions large leak and p1000 fuel metering. Can anyone point me in the right direction to take care of these. 2000 xj8 vdp
Old Aug 12, 2012 | 10:41 AM
dsnyder586's Avatar
P1000 means the OBD system has not gone through all of the checks, so scratch that one off the list. It changes to P1111 when it is done- I just wnet through explaining that to a smog tech (he didn't believe me until it passed)
Old Aug 13, 2012 | 08:03 AM
tilbury's Avatar
HOw do I get it to go through all it's checks?
Old Aug 13, 2012 | 08:19 AM
+1 on the P1000 / P1111
Nothing to worry about unless you must have P1111 to pass inspection. The checks will complete themselves as you drive or you can force them faster by going through a number of 'Drive Cycles'.
P0455 : EVAP system leak detected (large)
Possible Causes
Fuel cap off
Fuel cap seal defective
Fuel Tank leak
EVAP system leak - canister or pipework damage
EVAP valve to engine purge pipe blocked / damaged / leaking
EVAP valve operating vacuum hose leak / blockage
EVAP valve failure
EVAP valve to ECM circuit open / short / high resistance
Old Aug 14, 2012 | 09:34 PM
tilbury's Avatar
Is there a place I can find the schematic for the evap system?
Bcrary3
Feb 21, 2023 04:29 AM
Terry H
Jul 4, 2017 05:48 PM
KarimPA
Sep 27, 2015 08:46 AM
Jpav27
Sep 26, 2015 03:33 PM
tonyforman
Sep 10, 2015 07:23 PM
