2000 XJ8 Engine Swap-Is any 4.0 swapable?
Old Sep 4, 2012 | 01:07 PM
jagnicifant's Avatar
Default 2000 XJ8 Engine Swap-Is any 4.0 swapable?
Hi All,
I am considering doing an engine swap on my 2000 XJ8. I am trying to source an engine from a salvage vehicle that suffered extensive rear or side damage but where the engine is OK.
Are there only a limited number of "wrecked" XJ8's available.
anyone know if there are other Jaguar models whose engine would be "plug & play" to fit in my 2000 XJ8.
I want to be able to expand my search as wide a possible.
Thanks!!!
Old Sep 4, 2012 | 01:10 PM
Sean B's Avatar
An XK8 of the same vintage. It depends on the original if it's AJ26 or AJ27, I think it'll be a 27. Do the VVT connectors come out of the top or thru the timing cover?
Old Sep 4, 2012 | 01:24 PM
Hi Sean,
Yes the VVT connectors do come out of the top.
Thanks,
Old Sep 4, 2012 | 01:35 PM
I am seeing a number of XJ8 Vanden Plas (for example) with lower miles but the engine is listed as 4.0L. will that engine work in my 2000 XJ8?
I am just trying to search the largest available number of options to find the best engine with lowest miles. & for an easy swap.
Thanks!
Old Sep 4, 2012 | 03:55 PM
Sean B's Avatar
yep that'll fit, but what is it, 26 or 27, for ease if fitting you need a low miles 27, the later the better, like 02/3....no timing rebuild for example, or cam swaps, or flex plate swaps, or.....
Old Sep 4, 2012 | 07:32 PM
avt007's Avatar
Stay away from the early 4.0s and the cylinder wash issue.
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
cissdm
May 3, 2016 06:02 AM
obwoodie
Sep 3, 2015 07:45 PM
pocketrocket
Sep 3, 2015 07:44 PM
XFR_Gold
Sep 2, 2015 12:24 PM
