2000 XJ8 turns over but won’t start
Old Feb 12, 2025 | 01:30 PM
RandyS's Avatar
Yes sir...in cases like these, getting a tow to the shop and biting the almost
$500 dollar bullet is the only solution...that is unless you have friends or
associates who have the needed skills and time. Needless to say that
finding a respectable shop, with the needed familiarity with Jaguar repair
procedure can be challenging in its own right.
Old Feb 12, 2025 | 03:34 PM
Parker 7's Avatar
Last ditch try would be to remove rear trunk liner and bang on tank at the same moment with battery charger directly on socket 5 of the fuel pump socket # 5
Again with blade type connector , first try before liner removal
50 amp start setting ? the charger may shift / revert to normal 10 amp setting
This would give a chance to see if the pump motor connector sockets are burnt meaning pump replacement
The fuel pump motor has a ground wire that comes back around to the side of the battery well
On the battery connections normal power route there is a protection module ( mega fuses ) on the battery cables in the trunk that the terminal nuts can get loose
Chris Ryan
Jul 29, 2020 07:27 PM
jakesjag
Jul 21, 2020 02:24 PM
Miss Charlee
Oct 5, 2016 07:03 PM
jadedragon1800
Aug 6, 2012 07:23 AM
jpjag2011
Jul 30, 2011 09:14 PM
