2000 XJR bypass hose
Old May 4, 2012 | 09:42 PM
bergxu's Avatar
Default 2000 XJR bypass hose
Gents,
The bypass hose on my '00 XJR was very swelled up so I cut it off and obtained a replacement. This is the 90 degree elbow hose that is on the back side of the water distribution pipe. I'm having a hell of a time getting the new one on so I'm thinking I have to remove the metal pipe in order to get more clearance. Is it just held on with the two bolts at the front of each cylinder head? If someone could post JTIS instructions, that would be swell (pun intended)
Old May 5, 2012 | 07:37 PM
JaguarXJR02's Avatar
this is the thread that talks about removing the supercharger. you have to remove the "water disribution pipe" to get the supercharger out, so the PDF is in there
maybe this will help you
https://www.jaguarforums.com/forum/x...f-files-58889/
good luck
Old May 6, 2012 | 07:07 AM
bergxu's Avatar
Many thanks! I'll have a look through the files and see if it contains what I'm after. Pretty sure it'll just be a matter of releasing the two bolts on each head but just want to make sure
Old May 6, 2012 | 12:06 PM
Sean B's Avatar
I found using the right hose clip tool really helped with that pipe, up until then it was a case of using jubilee clips instead of original.
If you don't mind releasing the thermo housing it is a lot easier, as you're thinking.
Old May 7, 2012 | 07:19 AM
bergxu's Avatar
Thanks Sean,
I wound up releasing the water delivery pipe from the front of each cylinder head. As I did this over the weekend, I wasn't able to obtain new o-rings for the pipe connections to the heads so I got the new hose on, put the water pipe back on and crossed my fingers. So far, 50 miles and no leaks. Now to figure out what else is causing my ABS light, ASC NOT AVAILABLE and TRACTION NOT AVAILABLE messages, as I just had the ABS module rebuilt, hoping that was the silver bullet...
Old May 12, 2012 | 05:59 AM
bergxu's Avatar
Ok, quick update;
As has been discussed here many times before, my ABS and traction unavailable messages were sorted with a clean of the right front and left rear wheel speed sensors as well as new harness links to each of them.
Always nice to sort these types of things out!
Old May 12, 2012 | 06:00 AM
bergxu's Avatar
^ I forgot to mention I had codes C1145 and C1175---hence the RF and LR sensors being the culprits.
dsnyder586
Dec 29, 2024 07:39 PM
KarimPA
Sep 12, 2015 08:15 AM
stype40
Sep 9, 2015 08:14 AM
Jay48
Sep 7, 2015 09:30 PM
1100me
Sep 7, 2015 06:26 AM
