2000 xjr MAF sensor correct part number please help.
Hi all,
I get some rough running symptoms in my 2000 xjr now and again but mostly the car runs fine but does throw up the code p0101, sometimes the car may stall while doing a 3 point turn but this is rarely, when I first got the car i noticed the MAF sensor had some yellow writing on it which told me it was changed at some point from a scrap yard. Ive cleaned it a couple of times but this problem keeps coming back, ive been told that one way to test the MAF is to unplug it while the car is ticking over and if the engine stalls out then most likely the sensor is faulty and needs changing, my car revs drop then instantly goes back to ticking over nicely.when the plug is removed.
The part number on this sensor is LNE1620CB, but is this the correct sensor for my xjr as while looking for a new one this part number looks to be for the 4 litre non supercharged model, can anyone help me out with either the correct part number or tell me if this is the correct sensor I need please.
Many Thanks.
Many Thanks.
motorcarman (04-21-2020)
Well it turned up for when I got home from work, over the weekend I did also take of the throttle body and also the egr valve and took it apart and gave them both a good clean, egr was caked and the pin was a little sticky trying to move up and down, after the clean it was like new, then put the maf on an hour ago the took for a test drive just a couple of miles, it was the best the car had drove since I bought it over 6 months ago, so smooth and responsive feels like a different car. Thanks for your help.
bobomaggie
05-25-2010 09:18 AM
