2000 XJR "restricted Performance" wont accel over 75mph
Old Sep 24, 2009 | 05:39 PM
ken@britishparts.com's Avatar
You will need to pull engine codes.
Old Sep 29, 2009 | 01:28 AM
Teck4Jag's Avatar
if the happens at or above 3000rpm your secondary fuel pump might be at fault..
also if the secondary fuel pump is beginning to fail you may have a slightly longer crank prior to start up
Old Dec 7, 2009 | 12:25 PM
pingj's Avatar
My wife has an '02 XJR and the engine code is P1646 and has been hesitating and stalling as well.
The code indicates the Fuel Pump Relay 2 Failure.
Where is the secondary fuel pump relay located?
xjrjag
Oct 24, 2024 03:09 PM
peterg19
Feb 10, 2023 09:02 PM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
XFR_Gold
Sep 2, 2015 12:24 PM
