2000 XJR slow to warm up
Old Sep 25, 2012 | 10:38 AM
bergxu's Avatar
Default 2000 XJR slow to warm up
Gents,
Now that the weather is cooling off for autumn here in the Midwest, I've noticed that my XJR takes a rather long while for the coolant temp gauge to get up to the normal mark. My heat seems to be fine, although it hasn't been cold enough to need it full blast yet. About the only time the gauge will get to normal is after I've shut it off and let it "heat soak" for a while, then it's back to normal....until I've gotten back on the highway where the gauge will fall from normal about 4-5mm below that. Think I have a failing stat?
Thanks all!
Old Sep 25, 2012 | 05:42 PM
JaguarXJR02's Avatar
that does seem odd, my car gets to operating temp within 5 minutes of startup
you should consider getting a "realguage"
Old Sep 25, 2012 | 06:55 PM
RJ237's Avatar
Could be the thermostat, or maybe the sensor. Try disconnecting and cleaning the plug first.
RJ_________________
97 XK8 86K mi
Old Sep 25, 2012 | 07:41 PM
avt007's Avatar
Probably the thermostat sticking open, I have had that on my Jag and a couple other cars. It's cheap and easy to change.
Old Sep 25, 2012 | 10:32 PM
abonano's Avatar
+2 on stuck thermostat - My Jag at full operating temperature within 5 minutes of engine starting..
Old Sep 26, 2012 | 06:51 AM
bergxu's Avatar
Thanks fellas; and you say full temp within 5 minutes even in cold weather? As when its warm out, my car is probably at full temp within about 5-7 minutes as well.
Old Sep 26, 2012 | 07:51 AM
JimmyL's Avatar
These engines are made to warm up quickly. The engine water jacket doesn't hold a lot of coolant and it's supposed to warm up quickly to cut down on wear - at least that's what I've read. Thermostat sticking open sounds like a good bet.
dsnyder586
Dec 29, 2024 07:39 PM
peterg19
Feb 10, 2023 09:02 PM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
XFR_Gold
Sep 2, 2015 12:24 PM
