2001 Jag XJ8 white smoke a lot
Old Feb 15, 2018 | 01:46 PM
AbasttaJuan007's Avatar
Default 2001 Jag XJ8 white smoke a lot
good day! I just bought the car at a storage room was saved for 7 years with 85k miles, but didn't start so I took it home, then after several time and a new battery car start but has a lot of smoke, a leave it running, to see if it goes away, and it went away for a while, change oil, check levels are okay, so I drove it and message at dashboard reads coolant is low, I look thru the rearview mirrors and notice that has a lot of smoke, can someone tell me what could be? and by the way the hood on right side won't open, it was open but I closed to drive it. how can I open the hood?
Old Feb 15, 2018 | 02:33 PM
Fraser Mitchell's Avatar
You've posted in the wrong forum.
Your car is an X308 model series. If you post in the forum for the X308 1997-2003, you should get some answers. However, it does look as if you might have a head gasket failure, but I'm not an expert on these particular V8 engines.
Old Feb 15, 2018 | 02:42 PM
Originally Posted by AbasttaJuan007
good day! I just bought the car .....
Welcome to the forum AbasttaJuan007,
I've moved your question from X351 to X308 forum. This is the place to post questions about your model.
Old Feb 15, 2018 | 05:10 PM
Lady Penelope's Avatar
See topic in this link as it is the same engine :
https://www.jaguarforums.com/forum/x...-video-196623/
Old Feb 15, 2018 | 05:11 PM
NEECAPR's Avatar
Default White Smoke
I'm with Fraser: The head gasket fault is a real good bet, especially when also losing coolant. Easiest, quickest way to find out if that's it and which cylinder is a compression test on all cylinders. If it's a head gasket, that cylinder will, of course, be below the others. But, that test is not certain to find a small leak or multiple leaks
If it idles rough with a one weak cylinder, low compression will very likely show. And, that spark plug may also look pretty cold, but, maybe not dead. If it idles smoothly, I don't think a leak that small will show on a compression check, but, still the plug might look colder than others. Would take more ideas than I have now.
BTW, the oil pan isn't getting coolant is it? If so, the oil pump will get coolant while the dipstick shows oil. Only way you can initially tell is if the level is rising. Draining the oil may be a smart part of this checkup.
XJL
Jun 13, 2023 04:12 AM
dww
May 2, 2014 09:50 AM
rogerdodger
Sep 23, 2012 06:49 AM
Meatpotatoes
Jan 19, 2012 07:12 AM
meatman
Aug 26, 2009 01:32 PM
