2001 jag XJR
Old Apr 22, 2011 | 07:16 PM
eddievargas's Avatar
Unhappy 2001 jag XJR
Hey guys taking out my supercharger out of my car the coupler is going bad.I got the supercharger loose but no luck pulling it out I don't know if there are metal dowels on the back or do i have to take my throttle body out of the way. Hey if you guys know anyone in the jag forum that may have an idea please throw me thread need all the help i can get.thanks
Old Apr 22, 2011 | 11:27 PM
plums's Avatar
Perhaps you have missed a fastener or some other part of the procedure.
One of the stickies ought to include a download location for JTIS if you search for it.
What signs have led you to believe that the coupler is on the way out?
Old Apr 23, 2011 | 01:57 AM
Sean B's Avatar
There are dowels. I've disconnected the throttle elbow and bypass valve, also got the throttle body away too, basically you have to get a bit of stuff clear to remove it. You also have to take the thermostat housing off and pull the hoses down to get it clear and out. It's worthwhile doing this as the egr valve on the back of the elbow is usually full of gunk and the TB would benefit from a cleanup also.
Are replacing the coupler and bearings? If you strip the nose off first, make sure you grease the needle bearings with some hi temp grease - another thing, if the paint is flaking on the rotors, you can strip the rest off without loss of performance, I polished mine after porting it. Hope that helps a little, it's not an easy job. takes me a day of plodding to get it out and back in.
toronadomike
Jan 22, 2026 10:13 PM
Forcedair1
Sep 8, 2025 01:57 PM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
