2001 XJ8 Jaguar crankshaft position sensor
Old Mar 29, 2011 | 06:29 PM
CharcoalJag's Avatar
Default 2001 XJ8 Jaguar crankshaft position sensor
Anyone have a diagram of where this is located? Been troubleshooting for days now. No codes come up, only showing engine in safe mode. Car wants to turnover but won't...no spark! Thinking THIS may be the problem. Help!
Old Mar 31, 2011 | 07:22 PM
jimlombardi's Avatar
Default Here is the JTIS diagram of the engine contol sensors
Hi CharcoalJag
Here is a JTIS illustration that shows the location of all of the engine control sensors including the crankshaft position sensor. It has the reference of #3 in the table assocated with its location on the diagram illustration (its placement on the engine). It looks like it is at the rear end of the engine block.
Crankshaft position sensor diagram.pdf
Best way to view entire image when the PDF opens is full screen mode. Click on the menu - Window then Full Screen Mode. Use the escape key (Esc) to return to the normal screen mode.
This diagram is the same one for 1998 thru 2003 XJ model range (except the knock sensors shown are for the AJ26 engine).
Here is the knock sensor diagram for the AJ27 engine:
https://www.dropbox.com/s/61gb1a9g6q...lustration.JPG
Note the difference between the knock sensors - AJ26 engine has the wire coming out the top of the sensor wire connector (looks like a nut), the AJ27 engine has the wire going into the donut type of connector (that mounts on a stud, then it tightened down with a nut).
Hope this helps
Jim Lombardi
BrentGardner
29
Dec 16, 2024 12:13 AM
MJ'S Jag
Nov 10, 2022 08:14 AM
Drew2006
Nov 24, 2015 11:14 AM
celticpiping
Sep 18, 2015 06:17 PM
dpappyp
Aug 27, 2015 06:31 AM
