2001 XJR P0730, no gears while in D
Hello all,
I was driving in sport mode very hard today and while rolling, lost all gears while in D. Pulled over, cycled between D, P, R (which worked!) then back to D (while then worked thankfully).
I rolled to a stop and while in D was able to rev freely far beyond the protective 3k limit you have in P.
Looked with the code reader and had P0730 stored - incorrect gear ratio, which I guess makes sense if the RPM was able to go between idle and maybe 6k while it 'thought' it was in gear.
I couldn't make it do it again, but the big question is why, and even bigger, how can I fix this?
Thank you!
Thank you!
Jack T. Harper
Oct 15, 2023 04:54 PM
Britrover
Jul 13, 2020 12:50 AM
