2001 XJR P0730, no gears while in D
Old Nov 22, 2025 | 08:17 AM
TomX350's Avatar
Default 2001 XJR P0730, no gears while in D
Hello all,
I was driving in sport mode very hard today and while rolling, lost all gears while in D. Pulled over, cycled between D, P, R (which worked!) then back to D (while then worked thankfully).
I rolled to a stop and while in D was able to rev freely far beyond the protective 3k limit you have in P.
Looked with the code reader and had P0730 stored - incorrect gear ratio, which I guess makes sense if the RPM was able to go between idle and maybe 6k while it 'thought' it was in gear.
I couldn't make it do it again, but the big question is why, and even bigger, how can I fix this?
Thank you!
Old Nov 22, 2025 | 08:46 AM
xjack's Avatar
Check the fluid level before digging any deeper
Old Nov 22, 2025 | 09:19 AM
motorcarman's Avatar
Info for you.
File Type: pdf
File Type: pdf
Old Nov 22, 2025 | 10:18 AM
TomX350's Avatar
Thanks both, I'll check how to look at the level and go from there.
Much appreciated.
Jack T. Harper
Oct 15, 2023 04:54 PM
fs3
Mar 7, 2022 10:23 AM
Britrover
Jul 13, 2020 12:50 AM
quartetchiang
Aug 7, 2018 09:33 AM
shakil
Feb 9, 2014 06:02 PM
