2001 XJR Parking Brake Warning Light
Old Jan 1, 2024 | 02:28 PM
Stuart1960's Avatar
Cool 2001 XJR Parking Brake Warning Light
The rear brakes were recently bled, and since, the parking brake warning light is staying lit, even though the brake handle is in its lowest, released position. I'm assuming that the switch is probably stuck on. where is the switch located, and how easy would it be to replace, if I can't un-stick it? Thanks.
Old Jan 1, 2024 | 04:56 PM
Quadcammer's Avatar
Could it instead be that your brake fluid is low?
Old Jan 2, 2024 | 01:03 AM
Stu 1986's Avatar
From memory the handbrake switch is underneath the lever, I think if you remove the gaiter you can access it. But like quadcammer says, might be worth checking your levels.
Old Jan 2, 2024 | 03:10 AM
M. Stojanovic's Avatar
From the Driver's Handbook:
Old Jan 3, 2024 | 01:46 PM
Stuart1960's Avatar
Default 2001 XJR Parking Brake Warning Light
Thanks for all your responses.
I checked the brake fluid reservoir, and it is topped up to max. Ref the table below, the light (Canadian version) AND the warning message are both on, so maybe I have a fault with the brake fluid level sensor and/or the handbrake switch.
Had a look for the handbrake switch, but couldn't see it (difficult to access with being so close to the driver's seat!).
How easy is it to check/replace the brake fluid level sensor?
Thanks in advance.
RoxHan
May 19, 2023 05:41 PM
uncleken
Jun 23, 2021 11:16 AM
garethashenden
Oct 20, 2020 01:07 PM
Wolfy
Jan 8, 2018 05:53 PM
ZMOP
Jul 18, 2009 04:56 AM
