2002 XJ8 warning light for atlternator
Old Jul 6, 2018 | 04:57 PM
wrd0225's Avatar
Default 2002 XJ8 warning light for atlternator
Does the warning light come on for the alternator when there is a diode gone bad?
Old Jul 6, 2018 | 10:20 PM
M. Stojanovic's Avatar
Not necessarily. Better to rely on the charging voltage - if below 13, there is a problem with the alternator.
Old Jul 7, 2018 | 01:42 AM
Lady Penelope's Avatar
If the large alternator output terminal post does not read above 13 .5 volts which is above the fully charged battery voltage of 12.75 volts you have a bad voltage regulator mounted on the alternator . If you have a bad diode in the rectifier on the alternator you will notice it in the radio on a AM station .. The local auto parts store will test this for free as they are in the business of selling you a new alternator . You can clean the small wire connector on the alternator as it's in a bad environment . If the alternator completely fails there is a fuse the is required to provide power to the voltage regulator before the alternator can generate power . This one fuse is also tapped into other systems which is a fault of the circuit design .
Keep asking questions and someone will help .
correctitude
Nov 13, 2013 04:14 AM
slmskrs
Nov 12, 2013 02:08 AM
vincent661983
Apr 24, 2013 08:13 AM
JLee
Oct 6, 2012 09:46 AM
tgregory13
Dec 7, 2008 07:31 AM
