2002 XJR - Fuel pump (s) ?
Old Jul 25, 2012 | 04:29 PM
nemw001's Avatar
Smile 2002 XJR - Fuel pump (s) ?
Can anyone tell me if there are two pumps in my 2002 XJR? I can see the top of one in tank in trunk, is there another? Or are there two in the tank itself? Thank you.
Old Jul 25, 2012 | 06:15 PM
JaguarXJR02's Avatar
all 8 cylinder XJRs are fitted with 2 fuel pumps
Old Jul 26, 2012 | 06:56 AM
nemw001's Avatar
Thanks - I only see one what appears to be the fuel pump assembly on top of tank, are they piggy backed in the tank or is there one located alsewhere like in the engine compartment or on undercarriage??
Old Jul 26, 2012 | 12:27 PM
Sean B's Avatar
what you see on top of the tank is the gas vent and valve assembly, the pumps are located inside and at the bottom of the tank, there are ways to find which pump failed, but it's safer just to replace both pumps, you don't want to do the job twice trust me.
It's generally a tank out job, you'll need a fuel line release tool kit to let the fuel lines release at the bottom of the tank accessed from under the car and around the back/above the diff.
Old Jul 27, 2012 | 07:17 AM
nemw001's Avatar
Thanks, already took tank out - for those who may try thgis I took driveshaft to differential end of driveshaft along with the rubber coupler and un-did the emergency brake adjuster and slid that out of the way, doing this made access to the two fuel lines on bottom of tank MUCH easier. I did replace the two of them with Airtex fuel pump # E2471 at a cost of $87.00 per. Thanks for the replies appreciate it.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
deanh
Sep 6, 2015 08:20 PM
Sprayall
Sep 3, 2015 07:49 PM
