2002 XJR tires
Old Oct 14, 2008 | 05:26 PM
hlgeorge's Avatar
Default RE: 2002 XJR tires
If you are looking for a factory look and that is the recommended size, why are you asking about a different size?
Old Oct 18, 2008 | 07:38 AM
remosusa's Avatar
The first two numbers are width and profile, so 255/40/18 is (255 wide/40% as tall/18 inch rim). You can play with the width and aspect/profile ratioa little, as long as you make sure the tire circumference stays the same as the factory specs (so your speedometer isn't off) and the width doesn't scrub the inner fender, etc. If you can't get specs for the circumference, make sure to check the total diameter or total tire height, usually if it iswithin a quarter of an inch or so you'll be fine (ride height, speedo accuracy, etc).
way2far
Aug 31, 2022 09:26 AM
Dicque
Sep 19, 2015 12:53 PM
johndahlheimer
Sep 16, 2015 05:44 PM
Armor6
Sep 14, 2015 07:56 PM
Numwen
Sep 6, 2015 12:30 AM
