2003 X308 Vanden Plas questions
Old Apr 1, 2018 | 08:09 PM
pdupler's Avatar
Originally Posted by bookman
You mentioned difficulty finding replacement rubber, vinyl, and plastic parts. Are there after-market manufacturers for those parts?
Thanks.
I think most everything critical you need to keep an x308 "on the road" is still available in the aftermarket, though its not always likely to be in stock at your local oh reallys. May have to order parts from a specialist and wait a few days. But what I'd run into was trying to keep up the "luxury" aspect of the x308, weatherstrip, trim, vents, switches, etc. Everything I've asked for at the Jaguar dealer the last few years is no longer available and I've had to search for good used replacements or figure out how to fabricate and repair. I'm lucky to have a local Jaguar salvage but here in Texas, much of their inventory is as crispy as my original pieces. Sadly, most of the last ten years I worked in an industrial district where there was no covered parking. Nine hours a day of Texas sun has taken its toll.
Old Apr 1, 2018 | 08:30 PM
bookman's Avatar
Thanks Highhorse. I'll check those sticky's out.
Old Apr 3, 2018 | 08:43 PM
Coventrywood's Avatar
Question Daimler Dilemma
Bookman,
In-between coil only or airbag suspension is the CATS with electronic shocks.
It gives the driver reactive suspension without drooping airbags or defunct compressors.
I know it appeared on XJR's, VDP Supercharged & XJ8 Sports. Not sure what else, how long, or if it came as part of another package or could be ordered specifically.
It wouldn't help body stance if vehicle is overloaded, but would assist with ride quality.
Where it shines is ride quality during aggressive driving. No one expects (or wants) a VDP to handle like an F-type. But a surprising number of Teutonic 'Mall Buggies' who attempted chasing me through increasing-spiral exit ramps appeared highly startled as they began to slide off towards the weeds. Sublimely entertaining!
Old Apr 3, 2018 | 09:29 PM
bookman's Avatar
For some reason I thought the X350 air ride system was the CATS system. Maybe I’m learning something new.
I bet that exit ramp trip would be a sight to behold. You made me chuckle with that one.
Old Apr 4, 2018 | 10:44 AM
Don B's Avatar
Some X308s were equipped with CATS, or "Computer Active Technology Suspension," which electronically varies the shock absorber damping rate between Firm and Soft.
In the X350s the coil springs were replaced by air springs, but the shock absorbers/dampers had similar Firm-Soft capabilities managed by what Jaguar now called ECATS, or Enhanced Computer Active Technology Suspension. This was based on ECAS, the Electronically Controlled Active Suspension system designed by Wabco, the air suspension OEM.
Cheers,
Don
Old Apr 4, 2018 | 10:49 AM
bookman's Avatar
Thanks, Don. That makes sense. I was only slightly wrong, I guess. (That’s somewhat like being a little bit pregnant, now that I think about it.)
Old Apr 11, 2018 | 08:29 AM
D. Fite's Avatar
2002 and 2003 is definitely the best years. I happen to have a very nice 03 VDP for sale. I'm in Southern Ohio between Cincy and Portsmouth.
Old Apr 11, 2018 | 10:31 AM
  #28
bookman's Avatar
D. Fite, can you tell me more about your 03 VDP? Send me a private message if you wish. Thanks.
ZillA
Jan 6, 2014 11:51 PM
Ipc838
Jul 8, 2013 04:12 PM
robertjag
Jan 19, 2013 09:10 PM
constantinus
XJ40 ( XJ81 )
Feb 4, 2012 04:03 AM
glocki
XJ40 ( XJ81 )
Apr 26, 2011 08:23 AM
