2003 XJ8 Query
Old Dec 14, 2010 | 02:32 PM
Fraser Mitchell's Avatar
A 2003 XJ8 will be OK as the issues you mention were all dealt with by then. The 4.2 engine does not have the issues of the 4.0 litre, but for this engine the car changed to the X350 aluminium model with another gearbox, (but same manufacturer - ZF).
Any Nikasil engine that has got to 2010 and is still running OK is clearly marked out by Providence to go to Mars and back. No sulphur now in petrol so it will probably last almost for ever. Cam chain tensioners were a problem until the new metal bodied items came out, but I don't know which year or engine number, but it was about 8 years ago.
As for autoboxes, what can one say ? They either seem to go forever, or fail just after you have bought the car, (only joking !). The fluid can be changed and there is a procedure on doing it despite what Jaguar or ZF may say. It can be beneficial but having said that, the last high-mileage car I had, a Mazda Xedos which I took to 128,000, I never changed the fluid.
Go onto any of the major makes forums and see the tales of woe. All cars have certain problems. My Maxda Xedos (= Millenia in the US) gave no trouble, but when I went onto the users forum it seemed like I had been very lucky with my car !
The main thing when buying a used car is its and whether it has been taken care of by its previous owners - serviced correctly etc. records and invoices all kept and so on.
Old Dec 15, 2010 | 09:51 AM
stanleyh757's Avatar
The only engine problem I have had with my 03 XJ8 4.0 (knock on wood) was the thermostat. When changing that out, I stripped the nuts that were embeded in the plastic. I corrected this by putting longer bolts thru the housing and using new nuts.No problems with the tranny.(Again, not on wood) at all.
Razor
Aug 28, 2019 08:34 PM
xjrjag
Sep 24, 2015 10:08 PM
Ipc838
Sep 13, 2015 03:27 PM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
