2003 XJ8 question
Old Oct 23, 2012 | 08:54 PM
ED P.'s Avatar
Default 2003 XJ8 question
Hello,
Would a 2003 XJ8 (VIN SAJDA14C63LF58712) have the metal secondary chain tensioners as original from the factory or would this car need to be checked?
Ed
Old Oct 24, 2012 | 09:56 PM
motorcarman's Avatar
You should have the newer metal body tensioners as well as the silent running pimary chains.
bob gauff
Old Oct 25, 2012 | 07:28 AM
OldMike's Avatar
I haven't found a definitive answer to your question, and I've looked -- maybe someone has something official from jaguar that would answer this question once and for all.
I do, however, believe that bob is correct :-)
Old Oct 25, 2012 | 02:40 PM
Sean B's Avatar
He is, any car manufactured after mid August 2001 will have the AJ27S spec engine, this has all metal timing equipment and later oil pump along with morse silent primary chains.
I've just noticed yours is an O3 Mike, what month was it manufactured in 2002?
Old Oct 25, 2012 | 03:29 PM
OldMike's Avatar
My driver's door label is almost worn off, but with a flashlight at the right angle I can see (I think) 05/02 for the mfg date.
Old Oct 25, 2012 | 09:50 PM
Careful Sean
ENGINES manufactured after August 2001 will have later spec timing components!!!!!
A car on the assembly line might get whatever engine is next in line.
Also a car in warranty could get a reman engine with updated parts!!
bob gauff
DrTripp
Mar 22, 2020 09:33 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
neruda
Oct 18, 2015 01:19 PM
corysansburn
Sep 10, 2015 06:15 AM
OkieTim
Sep 8, 2015 04:48 PM
