2003 XJR Cassette Eject Override
Good Evening, the car is a 2003 Jaguar XJR X308 with the factory premium sound system.
Does anyone know a way to override the auto-eject feature of the cassette tape every time the ignition is turned off? I would just like the cassette to stay engaged at all times.Thanks!
Actually, I run the Sirius XM radio through a cassette adapter. Satellite radio is all I listen to, but I have to push the adapter in every time I start the car.
Thanks for asking though...
My guess is no -- You don't want the wheels to stay engaged .. they get flat spots and slip.
In the beginning when more magnetism was used (reel to reel/ early cass.) the heads could be effected -- Don't believe that was a problem w/ later cassettes.
No, there is no direct swap for these. If you pull yours out you'll see. Here's an older thread of mine...https://www.jaguarforums.com/forum/x...5/#post1491946
Haven't had chance to try this yet, but I will tomorrow.
This forum rocks, big time!
Yeah, he should have made that a little more clear in the video.
Press the "Tape Eject" and the "AM/FM" buttons simultaneously to bring up the radio set-up screen. Then, press the "5" on the keyboard to bring up Automatic Tape Eject. Press "No" and you're done.
Press the "AM/FM" button and the "Tape Eject" button simultaneously and you will enter the setup mode.
Then press the #5 button to turn the tape-eject feature on or off. .
Baxter beat me to it........what he said!
dakine
Feb 9, 2014 12:49 PM
RDMinor
General Tech Help
Apr 27, 2013 12:53 AM
