5HP-24-PR Question for 01 XJR
Old Aug 27, 2019 | 12:19 PM
Britrover's Avatar
Default 5HP-24-PR Question for 01 XJR
Gents, I am finally getting to look into the Transgo valve upgrade and a have a basic question on this necessary upgrade.
Asking as searching through the forum I am only coming up with this part#, but the detail for this part mentions ‘Fits: ZF5HP-24 Equipped Audi, BMW, Jaguar and Range Rover Vehicles’ and believe there is a Mercedes transmission. Just looking for clarification so I get the right part ordered and get this enhancement sorted for my 01 XJR.
Old Aug 27, 2019 | 01:04 PM
motorcarman's Avatar
ALL 4.0 liter SuperCharged X100/X308 use the W5A580 (722.6) gearbox.
bob
Old Aug 27, 2019 | 01:12 PM
Britrover's Avatar
@ Motocarman
Thanks. Pardon my ignorance, so can you advise if the transgo 5HP-24-PR valve will be compatible with the W5A580 (722.6) gearbox.
Old Aug 27, 2019 | 01:15 PM
Carnival Kid's Avatar
Yes, as per Bob, the X308 non-supercharged XJ8 has the ZF 5HP-24 automatic gearbox, which benefits from the Transgo valve. Your supercharged 01 XJR has the more sturdy and more reliable W5A580 automatic gearbox, and as far as I am aware has no need of an upgraded pressure relief valve.
Old Aug 27, 2019 | 03:29 PM
If you just HAVE-to-HAVE a valve body upgrade you might consider the 'blue-top' solenoids?
bob
Old Aug 27, 2019 | 06:49 PM
Highhorse's Avatar
Excuse my ignorance, but why do you feel you need this work done to your valve assembly? As stated by Bob and CK...the W5 is a strong reliable trans, it was also used in Dodge and Merc Sprinter and Freightliner cargo vans... https://en.wikipedia.org/wiki/Merced...c_transmission
If I recall, this kit does not fit this trans. anyways.
Old Aug 27, 2019 | 08:28 PM
Some people just can't stand factory OEM?
Keep fixing it until it breaks.
Old Aug 27, 2019 | 08:40 PM
sar98vdp's Avatar
Lots of confusing comments here, but to pick up on those that have the correct answer.......
Your XJR has a Mercedes transmission.
No part for the ZF 5HP-24 will fit
end of story
Old Aug 27, 2019 | 09:09 PM
M. Stojanovic's Avatar
Upgrade to the XJR transmission (Mercedes 722.6) is not necessary. If, however, you have some shifting issues and suspect the Valve Body (which would be on a very high mileage transmission), you can get a rebuilt valve body with some upgrades here: https://revmaxconverters.com/product...em-valve-body/.
Old Aug 27, 2019 | 09:14 PM
King Charles's Avatar
"If ain't broke, don't fix it"
Southern US Proverb
Old Aug 28, 2019 | 11:19 AM
Highhorse's Avatar
Southern US Proverb
I thought it was... "If it ain't broke, drive it harder until it does" ....
webshark
Jun 20, 2020 07:59 PM
SteveSheldon
UK & Eire
304
May 31, 2019 07:29 AM
norfskate
Mar 27, 2019 11:11 AM
orangeblossom
Oct 6, 2017 09:39 AM
xjrsteve
Aug 22, 2011 08:26 AM
