5th to 4th downshift not so smooth
'00 XJ8 VDP
Transmission is starting to get weird - no gearbox fault or transmission codes according to Jag shop.
'sometimes' - shifting to reverse seems to dim the headlights and lower power.
'sometimes' - shifting to drive from reverse almost makes the whole car want to lunge forward.
'often' - downshift from 5th to 4th - you can definitely feel it.
Anyone deal with the same thing? How long did you have before replacing it?
I'm in love with the VDP - and will likely eat the $$$ to have it fixed.
Also, had a transmission flush about a month ago.
Did you disconnect the battery recently? Mine went through a phase like this, while it seemed to be re-learning, after the battery died, and I had to replace it.
Suggest seeing how it goes.
vwbusbits
Oct 21, 2015 05:52 AM
