5w -- Side marker bulbs etc...
Old Dec 14, 2015 | 08:39 AM
yeldogt's Avatar
Default 5w -- Side marker bulbs etc...
Amazon had the correct 5W bulbs for our Jaguars at a very good price -- 10 for $10 -- picked up two boxes last week. That's good price w/prime.
These are the european 2825 Sylvania/ Osram bulbs used throughout the car. They are often replaced with the more common 194's or other similar shaped but incorrect watt bulbs. The 2825's are brighter -- the others are 4w, 3.6W, 3.2W.
These are the real Osram bulbs from Italy .. normally two to a pack for $7. They list them as Sylvania 2825. TP basic miniature bull, 10 pack.
Two of mine were out -- so I replaced them all.
Old Dec 14, 2015 | 05:26 PM
ericjansen's Avatar
Just note that originally, the interior reading lights (front and rear - the ones you need to click on) are 6W, not 5W.
I guess all other's around the car are the 5W mentioned.
Old Dec 14, 2015 | 10:54 PM
luc's Avatar
luc
No sure that I understand the problem.
If you want 5watts, don't get the 194 instead get the 168. They are available at any parts store
Old Dec 15, 2015 | 07:14 AM
yeldogt's Avatar
The 168 is also not the correct bulb ... it's technically a 14v bulb .. I forget the W .. but it's not as bright.
The only places that have the correct bulb that I pass on a regular basis are Pep Boys and other large auto stores. They sell them in two pack cards for about $7 .. when they have them. They are 2825's ... and not from China.
The small auto store near my weekend place sells the 194's for everything.
I see that Amazon has raised the price and they don't have many -- I mentioned it to my coffee club in the city over the weekend and they all ordered them.
Edit -- My bulb sheet shows the 168 at 4.8w at 14v 3cp. / The 2825 is 5w at 12v and 4cp ... the 168 are 2.5cp. The 2825 is a long life bulb .... the 168's is not but is extended because you don't drive it at 14v.
Old Dec 15, 2015 | 08:59 AM
luc's Avatar
luc
If your charging system was only putting out 12v, your car and battery will always be dead, a battery is fully charged at a minimum of 12.6v
As a matter of fact most charging system put out around 14v.
So except if you have a voltage reducer, through wire resistance or other means, the bulb is going to see more than 12v
Those 2 bulbs are so close in specs that you will never see a difference
Old Dec 15, 2015 | 09:19 AM
Samilcar's Avatar
One bulb is a third brighter (and more than that assuming equal voltages), and is also a long life bulb? Ordered my 10 yesterday at $11.50.
Old Dec 15, 2015 | 09:59 AM
yeldogt's Avatar
Luc .. don't wish to be argumentative. I understand the charging voltages. The correct bulbs for our cars is the 2825's .... they are noticeably brighter. This is a good price for the european made bulb.
Just trying to be helpful.
The Coupe
Jul 16, 2013 02:38 PM
frcraig
Mar 22, 2012 04:34 PM
Innovative Detailing
Detailing / Car care
Mar 4, 2012 11:10 AM
