98/99 transmission compatability
Old Jan 15, 2010 | 11:22 AM
wesmc2's Avatar
Default 98/99 transmission compatability
I have a trans fault message in my 98 xj8 with 120k on it. Runs perfect in first and reverse, but never shifts. Fuses and relays are fine.
I see I could pick up a trans ECU and see if that fixes the problem.
After owning 4 98-2000 xj8s I obviously have some spares lying around, inluding a later tranny 5HP24 ('99.) Some sources say they are compatible, some say not.
If they are I'd rather drop in the tranny for free, then look into the electronics if there is an issue.
Old Jan 16, 2010 | 11:34 AM
wesmc2's Avatar
bump, thanks for any help
Old Jan 18, 2010 | 02:38 AM
Teck4Jag's Avatar
same unit
Old Jan 18, 2010 | 07:56 AM
wesmc2's Avatar
thanks, I knew they were externally identical, then a jag shop tells me they won't swap. Thanks for the clarification.
Poet
Feb 7, 2025 02:18 PM
MrWhite
19
Jun 14, 2022 07:49 PM
kthrash
Feb 25, 2019 10:20 AM
Poet
Oct 2, 2015 09:00 AM
JAMES1944
Sep 29, 2015 11:58 AM
